oil pan leak
Old Sep 13, 2003 | 03:21 PM
medic's Avatar
oil pan leak
I've got a minor leak from the oil pan gasket. Nothing major enough to require removing the pan as that seems to be a PITA.
Has anyone used MaxLife oil or anything to stop leaks like this or have any suggestions on how to stop/slow it down a bit without removing the cross member and pan?
Old Sep 13, 2003 | 11:28 PM
jkmay01's Avatar
Lil 8
not to much you can do there! You will just have to change the gasket!! but first try tightening the bolts on the pan to make sure they are not loose. Have you done anything to the pan before?
Old Sep 14, 2003 | 01:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
just a FYI...there's NO GASKET on the oil pan.
it's all RTV. only "gasket" is the rubber pieces on the ends by the crank. if you're leaking in that area i would check your oil/crank seals. the oil pan usually hold it's seal for a while.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
