engine/trransmission
Old Sep 14, 2003 | 08:47 AM
miteymax7's Avatar
whats good pplz...im doin a engine and transmission swap in my GXE,i was wonderin if any of you guys could tell me if i dropped an SE engine in would it be 2 much work in tryin 2 fit it perfectly....and im doin a 5spd conversion which im not worried bout,i can get that done. i jus need 2 know about the engine.thanks
Old Sep 14, 2003 | 09:54 AM
TightBlack97's Avatar
Where's Matt or Jeff??
This question has been posted some many times. If you have the money to do it then yeah go after it but you could get a VE auto pretty of those around and put a 5 spd in it easily!!
Old Sep 14, 2003 | 10:08 AM
Ninty-two-se's Avatar
no, the engine is not a direct fit... as tightblue said... sell your car and buy a 92-94 SE 5-speed or automatic(then do the swap)
Old Sep 14, 2003 | 07:42 PM
subs1000w's Avatar
acutually it should be a direct fit youd proboly need the ve xmember and mounts and such but it should bolt rightin just the wiring would be the fun part but with a fsm it sohuldnt be to bad my friend just converted his crx from OBD0 to OBD1 and he had to rewire everything and it took about 2 weeks but it works fine now
