overheating
Old Sep 15, 2003 | 11:21 PM
ednina05's Avatar
overheating
Hi max people......
I need some help with my 89 max. I just changed my radiator,and
is still heating up, aslo had my termo replaced not to long ago.
I drive it to work every day but lately the temperature is going up,
and I don't see any indication that I need a new water pump, is not
leaking, and I just got a new belt too, also the temp sensors are new I'm looking for some one that had this same problem. The only thing I need to repalce is water pump and sending unit. The weid thing is that sometimes is normal, and some other times its doesn't read, but when I
open it up it feels hot. Is any other maxima having the same gripe, and
is so what was it that fixed it?
EC
Old Sep 17, 2003 | 01:33 AM
nubiannupe's Avatar
OG Maxima.org Member
Originally Posted by ednina05
Hi max people......
EC
...and this has WHAT to do with "for sale"???
Old Sep 17, 2003 | 11:34 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
2 things - the water pump may be bad it dosent have to leak to be bad. another thing is that there may be air in the lines causeing the overheating. pop open the radiator cap and open the bleeder valve on the intake, start the motor and pour antifreeze in as you need it. before you do this wait till the electric fans kick on so you know it up to temp.
Old Sep 17, 2003 | 01:07 PM
nismo_s13's Avatar
I've been having the same problem.. although too much pressure builds up inside the rad and the hose just pops off and there goes all my fluid. It seems to do this every week, i had just changed the waterpump. Also alot of steam seems to be coming from the rad.. probably is cracked and needs replacing? What do you guys think i should do
Old Sep 17, 2003 | 02:17 PM
Matt93SE's Avatar
STFU n00b!
sounds like there's something plugging the system in your case. if it's popping off hoses, that's not good.
sounds like it's time to drain the system and try to flush out whatever's causing the blockage. could even be something as simple as a stuck thermostat.
Old Sep 17, 2003 | 02:49 PM
nismobaron's Avatar
Even new thermostats can fail. Sometimes the vanes on the water pump can corrode off leading to a barely functioning pump. As the other's have said, bleed the air from the system.
Nismo-s13: Look for a collapsed hose. If thermostat has failed, temp goes way into the red but shouldn't pop any hoses - unless hose bad or not tightened properly. You might want to bleed air as well - esp if pressure a problem.
Old Sep 21, 2003 | 04:26 PM
EdwardBobadilla's Avatar
Check my list, and still I drove it to my dads house from Pasadena to Orange County (which is about 45 to 55 mins depending on traffic) and the damn thing still over heated.
List of parts changed:
Thermostat
Radiator Hoses (top and Bottom and Hose That connects to thermostat)
Res Tank
Radiator Cap
Temp Sensor
Took off Radiator Cap / Air Bleeder Valuve and Poured Anti Freez in with engine running and Heater on MAX.
I did this about a week ago to stop the over heating, now its done it again. Do you believe my Radiator needs to be replaced as it is the only component left to change? Please tell me where I am messing up @. Thanks.
Old Sep 22, 2003 | 07:50 AM
drstillpatient's Avatar
Thermostat
Res Tank
Radiator Cap
Temp Sensor
Are your cooling fans switching on at all???
Old Sep 22, 2003 | 10:49 AM
Paul89SE's Avatar
Heater Core Is Plugged Up
Old Sep 22, 2003 | 04:25 PM
The heating fans do come on, I have the chiltons Manual, but it doesent show me how to take out my heating core. Should I try to do this myself or should i just take it to a place. The main symptom is Pressure Build Up, anyone know how much i should pay, if i cant replace it myself, to get my heating core unplugged? Thanks people i really appreicate the help and information.
Old Sep 22, 2003 | 06:11 PM
internetautomar's Avatar
mod or sell?
Power Flush at your local self car wash!
worked good on my buddies caravan.
(do so at your own risk)
disconnect both hoses .
Shove power nozzle in one end and pull trigger
Old Sep 23, 2003 | 12:18 AM
my uncle said to buy that new "prestone" kit that has the "T" like tool where u attach the water hose, and he said cut my heater hose, put it in between and try that. Anyone had any experience taking out their heating core? I wouldnt mind having the local radiator shop unplug mine for 50$ or just get a new one, i just need to know how difficult it would be to pull out.
Thanks for the suggestions people. Also i thought I was having fuel Injector problems because my car would do a minor "pull" effect when I pressed on the gas, turned out to be a bad PCV Vaulve
Old Sep 23, 2003 | 05:27 AM
mod or sell?
consider yourself lucky or perhaps just delayed on the injectors though.
Old Sep 23, 2003 | 12:38 PM
I changed the fuel injectors myself around 2 1/2 years ago. 540 for all injectors.
Old Sep 23, 2003 | 01:06 PM
broncoguy's Avatar
Heater cores are usually a pain in the a$$ because they are up under the dash and you have to remove a bunch of stuff (usually while laying upside down) to get at them. Other than that, it's not really a big deal- just like a baby radiator.
But, I have not actually done one on a Max, so it could be a little different.
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
