Any known special Plug gap on sohc v6 w/mild mobs.?
Old Sep 19, 2003 | 04:24 PM
punabrew's Avatar
I have a 90se with intake, high flow cat,cat back, jetchip, grounding kit, and I just got NGK Iridium Plugs. Is there any known gapping # that out performs stock gap #.
Old Sep 19, 2003 | 04:43 PM
DanNY's Avatar
Ad·min·is·tra·tor
nope, stock is best.
Old Sep 20, 2003 | 06:16 PM
internetautomar's Avatar
mod or sell?
If you add a Higher output coil then you can open up the gap for some more power.
Old Sep 20, 2003 | 06:32 PM
bvtran's Avatar
94c Big Max
The pre-set gap for all NGK Iridium IX is 0.039" which means, I don't think you really need to set them at all. But you should check the gap with a spark plug gauges that you could get from the store. If yours is like mine, which is 0.039", I wouldn't bother changing them since Iridium are designed to take more beatings than regular plugs, leaving at that low number would give you better fuel economy and power since the fire power is a lot quicker.
Old Sep 22, 2003 | 07:00 PM
punabrew's Avatar
thanks guyz, ill keep the at the pre set.
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
