Help!! Electrical problem!!
Old Feb 15, 2001 | 01:33 PM
Evil Yak's Avatar
For some reason my parking/corner lamps won't come on.
I can't figure it out. The headlights work ok, but the rest is all off.. it kills me. I can't drive at night without them. Anyway, everything else works, the blinkers, the hazards, stop lights..... but none of the parking lamps are doing anything. I'm sure the system's fine because they still blink when I turn on/off the alarm. Could it be the switch? I really need help guys, thanks!
Old Feb 15, 2001 | 06:27 PM
ghostmax's Avatar
Yak,
You might have a blown fuse. After I did my corner rewire, a lot of my lights went out, including the corner and parking lights. To check the fuse, open that little fuse compartment in the knee panel. Check the fuse which corresponds to the one on the chart on the cover of the compartment--should say something like "Cornering lamp, Sidemarker lamp." Sometimes the fuse can even look and test okay when it's blown. If you have a fuse (10, 15, 20 amps), try substituting it and then turn on the lights. Good luck. Usually, the problem is the fuse, so I would give that a shot first.
Peter
Old Feb 15, 2001 | 06:29 PM
Evil Yak's Avatar
How about..
If there was a blown fuse, would the aftermarket
alarm still be able to light the parking lamps?
Could it be the switch? I'm pretty sure its not
any relays. I just bought one and tried replacing
all the light relays.
Old Feb 15, 2001 | 07:14 PM
ghostmax's Avatar
Ooookay.....
I didn't read your post too carefully the first time, so I didn't know the lights still came on when you used your alarm. Ummm, don't really know anything about aftermarket alarms. Good luck.
Old Feb 16, 2001 | 12:16 AM
Evil Yak's Avatar
man, I figured it out...
I blew a fuse, as well as a bunch of wiring inside going from the battery to the fuse box. I guess I should really
learn to weatherproof my connections... I just did my own
corner lamp mod and we just had a huge assed rainstorm.
When I pulled out the wiring, it was all messed up and wet.
Boy oh boy!
Old Mar 29, 2001 | 06:36 PM
demian's Avatar
I'm having the same problem, but I have a 4th gen. I can't figure it out. Two of the fuses keep shorting out after I replace them. They don't even light up any of the parking lights/blinkers. I think there's a short somewhere in the electrical wiring. Any advice?
knight_yyz
Nov 6, 2015 02:34 PM
homewrecker
Sep 24, 2015 07:01 PM
