Advancing timing on VE, let me hear your results
Old Oct 1, 2003 | 07:23 AM
D-sta's Avatar
Thinking of advancing timing, what did u guys feel after doing it. Appreciate the responses.
Old Oct 1, 2003 | 07:38 AM
Matt93SE's Avatar
STFU n00b!
it works. get a timing light. run ONLY 93 octane. you'll be happy.
Old Oct 1, 2003 | 07:45 AM
D-sta's Avatar
I always run 93 octane, now I just moved it a little and it felt better but I don't have a timing light but at the shop I do, how many degrees should it be moved and what are the problems that can come if not done properly. Thanks for the response Matt.
Old Oct 1, 2003 | 07:49 AM
Matt93SE's Avatar
STFU n00b!
if you don't have a timing light, don't do it. period.
if you advance too far, you risk detonation and screwing up the engine.
Maxima-4DSC's Avatar
YoU CaNt SeE mE
basically if its not done properly and you advance it to much it can lead to pinging then detonation. But if its done right and advance a few degrees you should feel some more power. the factory is conservative with the stock setting so the car can run on regular gas. you can advance it and run 93 octane. just make sure you use nothing less.
Old Oct 1, 2003 | 08:22 AM
D-sta's Avatar
I barely moved it, but I am taking it to the shop and having it done with the timing light immediately. Thanks guys
Old Oct 1, 2003 | 08:28 AM
cneary812's Avatar
I advanced mine about 10k ago and all the previous hesitation I used to get went away and my mileage actually improved. Gives more oomph off the line.
Old Oct 1, 2003 | 09:26 AM
vwink182's Avatar
I dont have a timing light, nor do I know who does. Where do you get them and how much? thx!
Old Oct 1, 2003 | 09:34 AM
internetautomar's Avatar
mod or sell?
most any retail auto parts store, including walmart and the like.
Old Oct 1, 2003 | 09:41 AM
subs1000w's Avatar
http://www.harborfreight.com/cpi/cta...emnumber=40963
YoU CaNt SeE mE
i had a really one one the strobe finally went ! yea most any autoparts store will have one.
Old Oct 1, 2003 | 09:53 AM
Jeff92se's Avatar
I'm needing a caw
After you get the light, the next fun thing is getting a decent signal from the #1 signal wire.
Old Oct 1, 2003 | 10:14 AM
bgcease92's Avatar
i adavanced my timing to 20 degrees exacctly and i run 93 octane i did feel a little difference. i also used a timing light to get the exact timing perfect. you could purchase a timing light from autozone or even pep boys .
Old Oct 1, 2003 | 10:19 AM
Bryan H's Avatar
ummmm. rodger that sir
where was the timing light at the track?!?!?!
errrr
i'll be over here if you need me
Old Oct 1, 2003 | 10:59 AM
Gjohnson's Avatar
Does anyone notice that the engine idles higher on start up, with the timing advanced. I had a friend set mine with a timing gun, but it was hard to read the signal. I'm just wondering if this is normal or not. I feel a big difference from stock timing and I can't hear any pining at all.
Old Oct 1, 2003 | 12:58 PM
Aaron92SE's Avatar
NWP Engineering.com
I shaved .23 off my 1/4 mile time just by advancing it from 15 to 20 degrees. Yes, I had a timing light.
Jeff's right, some have a hard time trying to get a signal from the #1 coil pack. I was able to get a signal just by removing my FSTB and then clamping it on all the wires coming from that coil pack. Some can't get a signal by doing this, and also, the FSM doesn't tell you to do it this way.
The best way is to unplug the coil pack and use a spark plug wire to link it to the spark plug, then you can tap right into that spark plug wire.
Also, MAKE SURE you follow the base timing mode procedure or it won't work. I think Chilton's manual tells you how to do it. Have fun. Once you figure it out, you will be able to check your timing in 5 minutes or less.
Old Oct 1, 2003 | 12:59 PM
Maximan190's Avatar
this is like the first mod i did
i bumped it up like a millimeter, very slight advance
diego can i take it to andy, does he have a light?, mine is kinda broken and i like to check the timing periodically
Old Oct 1, 2003 | 01:48 PM
Gjohnson's Avatar
What about the high idling at startup, has anybody noticed this???
Old Oct 1, 2003 | 02:28 PM
Michael's Avatar
Back in a 3rd Gen.
could it be the quality of the gun giving people problems with this...i know a few people have had this prob? I have a nice craftsman gun with the dial on it...got it a while back in my racing days where you need a dial since most factory balancers dont have timing marks high enough. Think I paid like 70 or 80 for it or something...higher than your average gun.
Anyway I havent had a problem getting the signal by clipping it on the loop that the FSM says to. I do think that the way aaron says to do it is the best (and is stated in the FSM too) but I didnt have a problem getting a signal.
Old Oct 1, 2003 | 02:49 PM
Jack.'s Avatar
I've heard of other car's ecu slowly retarding the timing back to factory setting... Is this true at all?
Old Oct 1, 2003 | 03:07 PM
Aaron92SE's Avatar
NWP Engineering.com
I know that you can't tinker with timing on Maximas 95 or newer. I mean, you have to have a Consult device I believe. I'm sure it's true with some newer, smarter cars. But I've heard of some 3.5L guys being able to advance the timing with a friend at a dealership that hooked him up.
But as far as the 3rd gen Maxima, timing will not change unless you change it or the ECU sees fit to retard it whenever circumstances arise, like detonation. Nothing to worry about with your car. Just make sure you do it right so you don't mess up your motor.
Old Oct 1, 2003 | 04:41 PM
Jeff92se's Avatar
I'm needing a caw
I can get a decent reading but it's not like these timing guns were designed to clip over a bunch of wires that only send a weak signal vs one big plug wire that is already carrying a ramped up voltage from the coil.
Old Oct 1, 2003 | 05:06 PM
Gjohnson's Avatar
Are you guy's ignoring me??? LOL
Old Oct 1, 2003 | 05:10 PM
AscendantMax's Avatar
what does a timing gun do anyways? i know it's used to check timing but how does it work? sorry for the noob question
Old Oct 1, 2003 | 06:50 PM
Michael's Avatar
Back in a 3rd Gen.
lol yeah...
yes most of the time when you bump the timing you will get higher idle. You may have to adjust your idle if thats the case.
Old Oct 1, 2003 | 07:07 PM
CandiMan's Avatar
Say Candyman 5 times
Advancing your timing will increase your idle, it's a known fact. There's also a procedure in re-adjusting your idle. High idle problem solved
Mike H you GOTTA take a pic (or explain it's precise location) of this loop thingny. I've looked all over my engine bay and I couldn't find the loop so this is why I did mine the way Aaron said. Spicing a spark plug wire in between the coil pack and spark plug. This is a critical adjustment so I took the extra step to make sure I got a "true and easy" spark signal. I said it before and I'll say it again, I first adj mine to 20* drove around a couple weeks and I wasn't too impressed then I bump it to 25* and felt a big difference. Theoretically I don't know if the 25* improved my entire rpm band but I do know for sure the bottom end is A LOT better and for the auto VE that's were we need it the most.
Old Oct 1, 2003 | 08:48 PM
Aaron92SE's Avatar
NWP Engineering.com
Yeah, I was at the track one day and I tried 25 degrees several times and it didn't hurt me or help me. Wierd. But we have different cars and as we both know... results may vary. I just leave mine at 20* and be done with it.
Oh yeah, I tried 25 degrees one 60 degree day with 100 octane that raised my rating to about 96 octane instead of 93. So, I doubt I was detonating. But I know I didn't get faster or slower on average since I was running consistant 14.9s that day.
Old Oct 2, 2003 | 06:56 AM
Matt93SE's Avatar
STFU n00b!
errrr
there's a difference between someone like you dinking with it and someone who's never touched a timing light in their life. There's few people that I would just hand the keys over to- you're one of them.
Old Oct 2, 2003 | 07:39 AM
dmontzsta
I felt a little difference down low.
Old Oct 2, 2003 | 09:21 AM
MaDMaX024's Avatar
how about this for a high idle issue: advanced the timing and SOMETIMES it idles high. i have all these situations that happen sometimes..if they would just happen all the time, i could fix them!
Old Oct 2, 2003 | 09:16 PM
Michael's Avatar
Back in a 3rd Gen.
I will take a pic if I ever get the car back but I just looked in the FSM for the location. Its by the PS oil tank. Its page EF&EC-178 method C in my 93 FSM...I am sure you have seen that but its where I got the info to clip my light.
Old Oct 2, 2003 | 10:02 PM
Aaron92SE's Avatar
NWP Engineering.com
Here is a pic of where the "loop" is. There will be a loop wire sticking out of that box. Clamp onto that and you're set.
Old Oct 2, 2003 | 11:42 PM
MrGone's Avatar
Oh sweet! I think I know what it looks like too.
No more cramming old mustang spark plug wires down the hole and dealing with all that crap.
Tommarrow I get to dust off the timing light.
Old Oct 3, 2003 | 02:34 AM
CandiMan's Avatar
No f'ing way. It's 5am and I'm at work surfing the net. After seeing that pic I had to go outside with a flashlight to varify and sure enough my loop is there. After all these years I finally found it.
Old Oct 3, 2003 | 04:41 PM
Aaron92SE's Avatar
NWP Engineering.com
HAHA, glad I could help.
Old Oct 3, 2003 | 04:47 PM
Jeff92se's Avatar
I'm needing a caw
I tried that loop location per the FSM. I couldn't get jack for a signal. That wire might have been too thick or something but no go for me. I just do the #1 wire harness thing
Old Oct 3, 2003 | 04:53 PM
Aaron92SE's Avatar
NWP Engineering.com
Same for me. But it works for everyone else. I couldn't get a signal with the loop. I was probably doing it wrong. But oh well, I got a signal just by clipping it on my #1 wire harness.
Old Oct 3, 2003 | 05:28 PM
YoU CaNt SeE mE
look advancing the timing is gonna give you better power obviously. just do it right you dont wanna have to deal with detonation. If you dont know what a timing light looks like or how it works, have someone experienced do it for you and learn from them. then you can play with the timing after you KNOW how to do it. hey wait my timing light is craftsman,,,does this mean i can just get a new one ?? or is that just tools ...hummm ill ask anyway...
Old Oct 3, 2003 | 06:32 PM
MrGone's Avatar
Aaron, your not going to believe this, but by using that loop my timing light stays on almost constantly, with a small pulse. I just hooked it onto the coil harness and bingo, thats what I'm looking for
Now I just need to find the reference point so that I can get a correct reading on the timing. One things forsure, it isnt as easy as the mustang is
Old Oct 3, 2003 | 09:55 PM
Aaron92SE's Avatar
NWP Engineering.com
Huh? Your reference point in the timing pin. It's above and a little to the right of the crank pulley.
Also, are you sure that you have your ECU locked in base timing mode as the FSM tells you? If it's not locked it, then your timing will fluctuate and will give a useless reading.
