Horayyyyyyyy Maxine Finally Has Brakes!!!!!!
MY BABY FINALLY LIKES TO STOP AGAIN!!!!
it was the rear brakes needed to be adjusted
so now i have a completly redone brake system all for an adjustment
now its off to the muffler shop to have my exhaust redone,
fly money fly!!!!!!!!!!!
thanx to those who were nice enough to give me advice
sal
sal
Hey give me some advice my brake pedal goes pretty far down before actually stopping. My dad and I replaced the drums and that fixed it but after a few days the pedal goes far down again. wtf? They stop the car just fine, I just like it better when I barely I have to press the pedal to make it stop the car.
dude i replaced everything that has to do with my brakes so the prob could be anywhere.
1) check the rear wheel cylinders if they leak there could be air in the lines, if there is a leak repair the wheel cylinders then bleed the lines.
2) master cylinder??? could be the problem
3) or you could do all this and waste money just to have the rear shoes adjusted, take it to a shop and like 40 bucks you'll be good
best of luck
best of luck
Good to see you finally got everything figured out! It's usually always a simple thing that someone's forgetting.. and adjusting that parking brake takes forever if you don't want to tear everything apart and adjust it by hand.
best of luck
best of luck
Glad to hear everything going AOK again
Jaguax - check rear shoes. If worn, replace. If wheel cylinders seeping, replace & do both sides. Check front pads & calipers. Check flexible hoses to make sure no bulges - get someone to stand on the brake pedal. Bleed brakes, adjust park brake - lever shouldn't have any more than 3 - 5 "clicks". If still poor pedal feel, master cylinder.
thanx a lot guys... i just got home from the exhaust shop, now my baby is good to go again!!!!
word of advice for those who dont know.... never leave your car behind when you move to the beach!
she gets jealous and doesnt wanna work anymore!
Originally Posted by Matt93SE
oh.. FYI.. the parking brake lever is supposed to have 8-10 clicks according to the nissan FSM.
Most safety inspectors here would fault (but not fail) the park brake lever if nothing happened for first 4-6 clicks - as it's a bit disconcerting for nothing to happen over that range .It's also an emergency brake & most people exert the most force in the first part of the movement - one of the most basic laws of physics.
Nissan recommends:
"a force exerted on the park brake lever of 44lbs (195N) which is equivalent to"
7-8 clicks for drums
8-9 clicks for discs
6-8 for ABS
44lbs is a reasonable amount of force - for holding car on a steep hill etc.
Personally, if your park brake lever goes up to 10 clicks in normal use, you're rear shoes need adjusting - and you'll end up stretching cables over a period of time.
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
