How do I take apart the A/T Switch???
Old Oct 11, 2003 | 11:19 PM
torontomaxima's Avatar
I've replaced every burnt lightbulb in the dash, and finally got to the A/T Switch... I take it out of the holding, replace the "P" and "C" lights... however when I tried to replace the A/T bulb I could not disassemble the switch! Can someone help me out here??? A write up/pics would be helpful.
Thanks in advance.
PS Is the bulb that illuminates the cigarette lighter the type as all the other ones on the dash???
Old Oct 12, 2003 | 08:29 AM
ChrisCheezer's Avatar
yes.. the buld in the lighter is like the one in the dash.. but the ones behind theA/T switch are these super small bulbs that u can only get from nissan.. they screw into the back of the A/T switch as well as in the back of all the other switches in the dash.. u dont have to take that switch apart to replace the bulbs
Old Oct 12, 2003 | 10:20 AM
1) The light in the lighter is the same as the ones in the dash??? Aren't all the bulbs the same in the dash? ie dimmer light, cruise cont. light, etc.
2) I'm refering to the "A/T" light... i know the P and C lights can be unscrewed and replaced... but the actual light the illuminates "A/T" is inside the switch... and that's what I don't know how to take apart .
Old Oct 12, 2003 | 12:39 PM
CandiMan's Avatar
Say Candyman 5 times
I don't thing the actuall "A/T" button illuminates, just the P and C illuminates.
Old Oct 13, 2003 | 03:22 AM
Are you sure??? I've read on several posts that they do... but maybe no one has ever opened those suckers, and hence when they go, they can't be fixed .
Old Oct 13, 2003 | 03:52 AM
nubiannupe's Avatar
OG Maxima.org Member
I think Mike's right.... Mine never lit up in all the time I've owned my Max. But ya never know. Maybe it WAS blown before I got it.... wtf do I know, after all???
Old Oct 13, 2003 | 08:18 AM
snowman2155's Avatar
Mine never lit up either!!!????
Old Oct 13, 2003 | 10:49 AM
Simatta's Avatar
It does not light up as far as I know. My first switch it was only the P/C that ever lit up. When those died I found a new one at a junkyard and only the P/C lights worked. Looking in the back, I only see the 2 bulbs for the P/C switch also.
In fact I always thought the A/T part was merely painted onto the switch.
Old Oct 13, 2003 | 12:12 PM
Interesting... can someone confirm this??? possibly an original owner who had the car from day one... I'm almost certian there has to be a light in there .
Old Oct 14, 2003 | 08:41 PM
Please someone confirm this ... it's been eating at me day and night... I've serached and found posts that say the switch does illuminate, and posts that say it doesn't
1) Does the switch (specifically the letters "A/T") illuminate?
2) How do you take apart the switch to change the "A/T" light bulb?
Old Oct 14, 2003 | 08:44 PM
DanNY's Avatar
Ad·min·is·tra·tor
YES IT LIGHTS UP!!
the P lights...the C lights the A/T lights.
Old Oct 14, 2003 | 08:54 PM
Originally Posted by DanNY
YES IT LIGHTS UP!!
WHOOOOOHOOOO!!! EXCELLENT thanks Dan.... now back to the original question how the hell do I take the bloody thing apart!?!?!? .
Old Oct 14, 2003 | 08:59 PM
DanNY's Avatar
Ad·min·is·tra·tor
you're going to need to split the switch..you can see in the pic how.
the green boot part is the bulb that lights up the A/T part.
Old Oct 14, 2003 | 10:12 PM
Thanks again! Just the info I was looking for - I didn't know if the switch had to be split - but now I do . Thanks again Dan .
Old Oct 15, 2003 | 09:35 PM
DONE!
Okay,
Just finished replacing the bulb so I saw it only fitting to post a write-up of how it's done...
1) Take apart the centre piece of the dash.
2) Pop out the AT switch by pressing on the two tabs near the top.
3) Once it's in your hand get a knife, or a really tiny flat head screwdriver, and separate the two plastic pieces near the bottom (one piece joined to the bigger plug, and the other joined to the smaller plug) - they are glued together on both sides... you'll probably hear a slight cracking sound - don't be alarmed .
4) Now that the bigger piece is free from the smaller piece, stick a small flat head screw driver in the arear with the plastic tab (near the bottom - opposite the P and C bulbs)... separate untill it is no longer "locked".
5) Now using pliers squeeze on this area: when looking from the bottom.
.....___VV__ <- SQUEEZE HERE (ON THE VV AREA)
|....................| NB: IGNORE THE PERIODS
and then pull on the opposite direction of the plastic tab (towards the direction of the P and C bulbs)
6) In addition to the piece you were pulling on, another piece also comes out... replace the bulb.
7) Assemble - except you must put that other piece in above the bulb and underneath the main plastic piece that you pulled out - just a little alignment, and push it in!
8) PRESTO, your're all done... don't even bother gluing the 2 pieces back together... the switch will work fine.
Do this at your own risk - I take no responsibility for f--- ups.
Oh, and BTW the bulb in the lighter is not the same as the other lights on the dash... I couldn't find it at radio shack, so I guess the dealer might have it.
Thanks to all those who helped me out on this one .
Old Oct 15, 2003 | 11:13 PM
«§»Craig B«§»'s Avatar
DONE!
sure it's not a 272-1092 12v minilamp like the rest of the small bulbs in the rest of the switches inside the dash?
from the pic it looks just like some of the others but with a plastic base with the legs wrapped around it like the ones that light up just above and below the fresh air vent lever (on the left side of the climate control)
Old Oct 16, 2003 | 12:26 AM
Torres's Avatar
hey Mike
well i guess ur goin' 2 have 2 show me how u did it on saturday...that is if ur still goin' 2 the junkyard??
l8er
Torres
Old Oct 16, 2003 | 07:53 AM
Originally Posted by Torres
hey Mike
l8er
Torres
No problemo, it's a nice DIY fix.
Old Oct 16, 2003 | 08:21 AM
DanNY's Avatar
Ad·min·is·tra·tor
yeah it's the same bulb as the other switches.
Old Oct 16, 2003 | 08:41 AM
To clarify...
The "A/T" bulb is the same as the other bulbs in the dash... I was refering to the bulb that illuminates the ring around the cigarette lighter... that one is slightly bigger and has a conjoined glass base - no rubber or plastic attachment... I'm going to the dealer today to get ripper off (if they have it).
Old Oct 16, 2003 | 09:14 AM
DanNY's Avatar
Ad·min·is·tra·tor
To clarify...
the ring around the cig lighter and the ash tray light are both a bigger size.
Old Oct 16, 2003 | 12:57 PM
Yeah I just came back from the dealer, and you can't just buy the bulb... what a surprise... - you have to buy that plastic assembly that goes around the lighter (which contains the bulb)... total price Canadian $12.35 - forget that!!! I'll just get my 50 cent micro lamp and solder it on to the contact.
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
