Timing chain cover
Old Oct 12, 2003 | 06:26 AM
skipfl's Avatar
Timing chain cover
HI I blew my timing chain on 1992 DOHC. Small half moon shaped piece came off engine. Was wondering if that piece can be repalced or if I need a complete timing chain cover. If so, how would I get one other than a dealer. Their price is $460.00.
Any help would be appreciated.
Skip
Old Oct 12, 2003 | 06:30 AM
MaximaBalla's Avatar
You should try searching, I'm sure you'll find some answer in there. Remember this, the search function is your friend!
Old Oct 12, 2003 | 05:14 PM
CandiMan's Avatar
Say Candyman 5 times
Originally Posted by skipfl
HI I blew my timing chain on 1992 DOHC. Small half moon shaped piece came off engine. Was wondering if that piece can be repalced or if I need a complete timing chain cover. If so, how would I get one other than a dealer. Their price is $460.00. Any help would be appreciated. Thanks Skip
Need more info
If someone told me they blew their timing chain, first thing to come to my mind is that you need a new motor due to the damage a blown chain can cause. What small half moon thingny are you taking about, apearantly this half moon thingny can be purchase at the dealer.
Old Oct 12, 2003 | 08:07 PM
internetautomar's Avatar
mod or sell?
once we have some we'll be able to help , Maybe
Old Oct 12, 2003 | 08:23 PM
MrGone's Avatar
contact Jeff92se, he still might have the whole timing chain cover from his old motor.
Old Oct 21, 2003 | 11:56 AM
Jeff92se's Avatar
I'm needing a caw
Nope. I sold the entire assembly to someone else.
Old Oct 21, 2003 | 11:57 AM
DARHAW-MAX's Avatar
How did you blow the timing chain?!
Old Oct 21, 2003 | 12:00 PM
Jeff92se's Avatar
I'm needing a caw
If your tensioners give out, it could create enough slack to break the chain. Or if your VTC assembly goes ******* up, then the whole assembly goes bye-bye.
Old Oct 21, 2003 | 03:55 PM
eric93SE's Avatar
Originally Posted by Jeff92se
******* up
Mmmm VTC's
Old Oct 21, 2003 | 04:54 PM
DARHAW-MAX's Avatar
Hmmm. I did not know that. Something to keep in the back of the cranium. I guess the next logical question is what would cause the tensioners on the timing chain to give out?
"******* up" as opposed to "**** up." I will definitely have to use that sometime tomorrow at work.
Old Oct 22, 2003 | 04:33 PM
maxima 94's Avatar
if you have a local auto salvage yard try to find a replacement there. it will be a lot cheaper than the dealer
Old Oct 22, 2003 | 04:36 PM
Jeff92se's Avatar
I'm needing a caw
If the part has a defect, there is nothing you can do. Even on my neglected engine, my tensioners were "okay". As for everything else on the engine, change your oil regularly and make sure the oil level is checked frequently.
BTW. The tensioners are not really "on the chain". They are bolted to the cover assembly and only contact the chain to take up the slack.
Old Oct 22, 2003 | 06:33 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
mmmm...tension.....*******....and new vtc's as of this comming nov 2nd ! yea no more clattering !
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
