Intermittent Starting Issues - F@#%!!
Old Oct 15, 2003 | 05:54 PM
-shock211-'s Avatar
Well guys...I haven't been around for awhile because I've been fixing my car every chance i get some spare time. I've fixed a lot of things lately and the car is running pretty good. But here's my latest PITA problem.
This is a little long, so go fill up your coffee.
Last week i started to have problems starting the car. I'd turn the key over and everything would get power except for the starter. Of course this doesn't happen everytime i start the car. it will happen maybe 1 out of five starts. So unfortunately it's that much harder to diagnos.
Like a dummy i went out and bought a rebuilt starter w/solenoid the minute the problem arose. Of course the car started fine at first but my problem came back.
So far I've tested the power wires from the starter and they are fine. The ground is fine as well.
There are two wires from the starter relay which I haven't tested yet but will tomorrow. One goes to the positive battery terminal and the other connects to the small power wire coming for the starter.
I'm thinking that the connection to the positive terminal from the starter relay wire might be weak. So i'm going to clean the terminal and make a new connection.
I also think that the relay could be malfunctioning too.
I know that the ignition is a possibility but i've never heard of an ignition having intermittent issues. it just dies.
Does anyone here have any ideas? Or any personal experience with their maxima on this subject?
Old Oct 15, 2003 | 06:47 PM
internetautomar's Avatar
mod or sell?
There was a thread about a week ago on this topic.
It boiled down to being a neutral safety switch If I remember correctly.
Old Oct 16, 2003 | 05:42 AM
-shock211-'s Avatar
thanks...i checked that earlier today before this post.
but i fixed the problem anyways....turns out it was the freakin' relay!!!!
Old Oct 16, 2003 | 11:39 AM
-shock211-'s Avatar
or so i thought....
it's not the god damn relay!!!
i think know that it's the connections to the starter relay under the relay box.
any suggestions?
Old Oct 16, 2003 | 02:33 PM
mod or sell?
You got stick or auto?
Old Oct 16, 2003 | 06:37 PM
-shock211-'s Avatar
auto 92 vg
Old Oct 16, 2003 | 07:20 PM
mod or sell?
You checked the NSS you said.
How did you check it?
Did you try to start it in neutral any of the times?
How about take it out of park and put it back in.
On mine I'm just slightly off so I have to start in neutral on occasion.
Old Oct 17, 2003 | 03:55 AM
CandiMan's Avatar
Say Candyman 5 times
Exactly, once in a blue moon my car (auto) will not crank. I'll giggle the shifter then it cranks/starts. Our shifter bushing are known to wear which might cause a cranking problem, even though the neutral safety switch is working properly.
Old Oct 17, 2003 | 07:13 AM
-shock211-'s Avatar
yeah i've tried starting it in neutral or taking it out of park and putting it back in park. none of that works for me.
i think what's happening is that there's a short in the wiring to the starter relay. because when i put in a new relay the car started about 10 times without a problem. then all of a sudden it won't start anymore. so i think the short in the wiring is shorting out the relay which inturn causes the car not to start.
if it's not that....it probably is the ignition
i replaced the power terminal connections but unfortunately that wasn't the issue either.
this fu&k!n sucks!!!
Old Oct 17, 2003 | 07:48 AM
mod or sell?
Sounds like its time to do a bypass.
You could always getto it like I did my elky years back.
Toggle switch under the dash.
Problem solved!
Old Oct 17, 2003 | 07:21 PM
-shock211-'s Avatar
Problem solved!
that's what i'm doing for the moment.
Old Oct 19, 2003 | 06:20 PM
mod or sell?
I hope you use a momentary switch not a toogle. I used the toggle because I had it lying around. bad idea though good for cold weather long cranks though
Old Oct 23, 2003 | 05:51 AM
-shock211-'s Avatar
do you mean using a push button switch as opposed to a toggle switch?
if i were to use a button it would be the push botton type.
but right now i'm just touching the wires together.
Old Oct 23, 2003 | 06:45 AM
mod or sell?
yup. you can even get ones with a cool mounting bracket to hook up.
or you can always go rice and get a start button
Old Oct 23, 2003 | 05:24 PM
-shock211-'s Avatar
i just might get the start button because its cheaper than replacing the ignition and will substitue for it.
ricey or not...money talks
besides i'd be lying if i said i didn't find the start buttons a little cool.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
