ECU Question
Old Oct 16, 2003 | 11:20 AM
Thinkster's Avatar
ECU Question
I know the procedure to pull an error code from the ECU, but I also noticed the pot that you turn with a small screwdriver to get the ECU into the "Display Error Code Mode" has a sticker labled "Idle Adjust" So it seems to me that there are multiple modes you can get into depending on how many times the LED blinks and you turn the pot to a certain direction. Like for error code mode, I think you wait till the Red LED Blinks 3 times, but what about for 1 time, or 2 times or 4 times?? Is there any info on what the other modes are or if you can really adjust the idle speed directly at the ECU?
Old Oct 16, 2003 | 08:32 PM
mtcookson's Avatar
i believe the modes are as follows (i'll check my fsm to make sure)
1: normal mode
2: a/f ratio
3: diagnostics mode
4: throttle sensor check/speed sensor check/ecu code reset
5: real time diagnostics mode
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
