Fidanza
Old Oct 20, 2003 | 09:11 AM
MONSTERMAX's Avatar
Fidanza
I have a 94 nissan maxima SE 5spd and was wondering if anyone knew where i can purchase a FIDANZA flywheel for my vehicle. Also i heard they were the best for the MAX. Is this true?
Old Oct 20, 2003 | 09:18 AM
reygarcia's Avatar
Loved by MrGone longtime
Get with Matt93SE. He sells them.
Old Nov 12, 2003 | 05:04 PM
StRacer718's Avatar
You can also get them from www.customMaxima.com
Old Nov 12, 2003 | 05:06 PM
Kevincleff's Avatar
Get it from Matt93SE
Great price and no hassle
search for his name and his sig will have a link to how to buy it from him
Old Nov 12, 2003 | 05:15 PM
Gjohnson's Avatar
Awesome guy to work with and you won't find a better price.
Old Nov 12, 2003 | 05:16 PM
Matt93SE's Avatar
STFU n00b!
You rang?
$350 shipped UPS ground. I've got a couple left. I do cash, check, MO, Paypal (if you wanna pay w/ credit card).
email me matt93SE@sbcglobal.net
Old Nov 12, 2003 | 05:35 PM
Gjohnson's Avatar
Originally Posted by Matt93SE
You rang?
Hold on, Ok Matt come clean. When did you start the new website with all the suspension mods. Man you never cease to amaze me. That is awesome.
Old Nov 12, 2003 | 05:59 PM
Matt93SE's Avatar
STFU n00b!
Last week sometime. there's more in the works, but that's all I'm showing you right now.
Old Nov 12, 2003 | 06:04 PM
Gjohnson's Avatar
Man I wish I had some money.
Old Nov 12, 2003 | 06:09 PM
internetautomar's Avatar
mod or sell?
90
Old Nov 12, 2003 | 06:10 PM
MrGone's Avatar
Matt, you've got me...
the only thing left I can think of for you to make is a completely custom brace/support/thingamabob that you welded to strengthen, for the rear suspension, where the parallel links bolt to the car. That or homemade control arms.
The only thing left you can do to your car is to make a full tube frame and cut out any unecessary metal .
Old Nov 12, 2003 | 06:12 PM
mod or sell?
Hmmm... cut out unneccesary metal. Hmmm.... don't really need those interior door frames now do we.
Old Nov 12, 2003 | 06:13 PM
AscendantMax's Avatar
no, the last thing he can do is change out the carpet...only stock thing left in his car!
Old Nov 12, 2003 | 06:17 PM
MrGone's Avatar
My carpet isnt stock.
Old Nov 12, 2003 | 06:20 PM
nice, how much did you pay to redo the whole interior?
Old Nov 12, 2003 | 06:25 PM
Matt93SE's Avatar
STFU n00b!
Ummmmm..... this guy?
http://www.mattblehm.com/pics/car/su...ssmember_1.jpg
http://www.mattblehm.com/pics/car/su...ssmember_2.jpg
http://www.mattblehm.com/pics/car/su...ssmember_3.jpg
After welding the seams, It's more than strong enough now. main thing you need to worry about on the frame now is the engine crossmember. I've broken one, and noticed some hairline cracks in this one now. I've got one more on the way, but I'm going to strengthen it before I install it this time.
Old Nov 12, 2003 | 06:26 PM
MrGone's Avatar
Just the floor carpet.
The stuff that came in the car was burned or something around the center console area and such, so I replaced it with the carpet from Jeff's old maxima. I was wondering if OE carpet is stock carpet. I just assumed stock meant the carpet that came with the car from the factory.
Old Nov 12, 2003 | 06:28 PM
yeah i got some minor tears in the carpet in the back. i guess OE carpet is considered stock carpet.
Old Nov 12, 2003 | 06:29 PM
Matt93SE's Avatar
STFU n00b!
OE carpet is still stock carpet. Maintenance/repair/replacing with OE isn't modifying, thus it's still stock. (unless you're changing the interior color by doing it or something.)
modifying means changing something, not just replacing with the same thing.
So replacing your O2 sensor isn't a mod. replacing your brakes with stock-ish stuff isn't a mod. dumping on a 12.6" rotor w/ Z32 calipers is a mod. (look for pics next week )
MrGone's Avatar
yep, thats it.
Oh yeah, I remember when that happened (your cross member breaking), I should probably double check mine, I didnt think about it.
Old Nov 12, 2003 | 06:32 PM
MrGone's Avatar
ohh, good example using the O2 sensor.
care to share more about the brakes? is this for the rear?
Old Nov 12, 2003 | 06:45 PM
Matt93SE's Avatar
STFU n00b!
fronts... rears are in the works, but probably won't mess with 3rd gens since I already did the Z31 conversion and the writeup on it.
let's say this on the fronts tho..
12.6" brake kit that's affordable, less than almost all the others out there..
Direct bolt on, requires no mods to the car or other parts to fit.
Uses easily replaceable parts that you can pick up at any parts store if you happen to be cruising down the road and wear out a brake pad. Same thing with rotors.
doesn't require funky hub adaptors or spacers or anything like that (unless your wheels can't fit over the calipers, then you'll need regular wheel spacers).
Plenty of pad compounds out there, from cheapo autozone pads up to Hawk, Porterfield, KVR, Ferodo, Axxis, Cobalt Friction, Performance Friction, etc etc etc etc.
Now for the the bad.... Z32 calipers are BIG. they don't fit under most wheels, without spacers.
17" (or bigger) wheels required..
Interested?
Old Nov 12, 2003 | 07:04 PM
cneary812's Avatar
Interested?
so you are saying you can bolt up the z32 calipers directly with the 12.6 rotors and no mods required!!! Please tell more!!!!!
Old Nov 12, 2003 | 07:09 PM
MrGone's Avatar
Interested? yes, because you always have or make really cool stuff.
Interested as in sending money your way? would be if I didnt already buy http://www.digitalbeta.net/images/92max/brakes1.jpg
Its really cool that your making the brake kit though, I thought it was going to be something for your car but that didnt make any sense
will your brake kit be able to clear the stock 5th gen 6spoke 17" wheels?
Old Nov 12, 2003 | 08:02 PM
Matt93SE's Avatar
STFU n00b!
are those the 26 or 30mm calipers?
If they're 30mm, I'll work with you on it if you supply the calipers. that's the hardest part of the kit is sourcing the Z calipers, whether new or rebuilt.
Old Nov 12, 2003 | 08:41 PM
bonzelite's Avatar
matt you're awesome.
remember, too, that my skyline 16" wheels fit over the Z32s.
the fidanza arrived well. thanks. i am now gearing up to remove the control arms.
will email you for more detailed queries. i have the other maxima now. it is red just like yours but not as fast. i love it anyway.
Old Nov 12, 2003 | 10:12 PM
Matt93SE's Avatar
STFU n00b!
Cool Chad..
I've got the ground kit made up and painted the tie bars black today. had a couple job interviews and was running around to the fab shops the past couple days, so I couldn't get on it... but I'll box it up in the morning and drop it in the mail. you shoudl have it early next week.
Tahnks!
Old Nov 12, 2003 | 10:41 PM
MrGone's Avatar
good luck with the interviews, hopefully you will still be able to offer your cool toys to the community
btw, 30mm on the calipers, and thanks for the offer, I didnt even think about it. I need to track down some wheels first though.
Old Nov 12, 2003 | 10:51 PM
bonzelite's Avatar
matt, there is no prob here. get to it when you can. i know you have a lot on your plate. this is casual. you are golden with me.
mr. gone, skyline r32 wheels fit perfectly: gts25t = z32. gtr will way clear those. just my bit. you may not want those wheels but they look gorgeous and are OEM nissan.
go to my site:
http://www.cardomain.com/member_page...page_id=401040
Old Nov 13, 2003 | 07:01 AM
Matt93SE's Avatar
STFU n00b!
Chad, remember this is for a 12.6" rotor too... not the factory 10.75" that came on the GTS and the Z32.
Old Nov 13, 2003 | 12:21 PM
Lordrandall's Avatar
Get the Fidanza from Matt, you'll love it!!!!
Old Nov 13, 2003 | 01:23 PM
MrGone's Avatar
lemme guess... the bolt is to keep the engine from turning over right?
damnit that would have been sooo much easier.
Old Nov 13, 2003 | 01:28 PM
Jeff92se's Avatar
I'm needing a caw
Uh no. Nothing inside there is threaded.
Old Nov 13, 2003 | 05:35 PM
bonzelite's Avatar
but lordrandall's was a z32, yes?
Old Nov 13, 2003 | 07:13 PM
Matt93SE's Avatar
STFU n00b!
Randy's brakes were Z32, yes....
the ones I'm working on now are something else. I'm still using the Z32 calipers, but 12.6" rotors instead of 10.7"
Mr Gone, the bolt was in there while I was trying to remove the pilot bushing. I didn't have a slide hammer and was trying to find something that would grab onto it to pull it out.
Old Nov 14, 2003 | 02:41 AM
MrGone's Avatar
I was thinking about that after I posted, I was walking out to my car and passed the spare engine and noticed there werent any threads, became confused and continued on to go to school.
Matt93SE
May 24, 2019 02:58 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
kenc15
Sep 25, 2015 06:38 AM
