Heres a really strange problem....
Old Oct 25, 2003 | 06:20 AM
blppt's Avatar
OK, nearest i can tell, this only seems to happen with 93 octane.
- The car always starts up and runs smoothly when cold.
- When the car has been warmed up and ran for any length of time, then is shut off and sits for like 20 mins-1 hour, when re-starting at least one of the cylinders is not firing, which results in an obviously really lumpy throttle. This lasts for approximately 2 mins, then the cylinder(s) start firing again normally.
I did replace the cap and rotor with generic autopartstore replacements, as well as the wires and plugs, which are Bosch +4s. I hear that people have had problems with the +4s and VGs, as well as not using Nissan original parts in the ignition system, so could any of this be my problem?
Again, as near as i can tell, this problem does not occur on 87 octane gas. Thanks in advance.
Old Oct 25, 2003 | 06:22 AM
drstillpatient's Avatar
maybe requires fuel injector cleaning?
Old Oct 25, 2003 | 06:49 AM
blppt's Avatar
You mean actually taking out the injectors and cleaning them, or the bottle stuff?
I have used the Gumout super concentrate once or twice since June. No change, really. You think it might be a dying injector then?
Old Oct 25, 2003 | 08:02 AM
i cant say for sure its the fuel injector...ive had a similar problem once or twice now...but mine was being caused by the idle air control valve acting up.
Old Oct 25, 2003 | 09:09 AM
Maroon'dMaxSE's Avatar
Try "LUCAS" products. my brother has a 1990 toyota camry and it runs madddddd smooth...dumps lucas in every oil change....they got a whole chain of products.... from oil stabilizers to fuel enjection cleaners to even transmission stabilizers..try sum of that..
Old Oct 25, 2003 | 11:04 AM
xdannyx25's Avatar
change the bosch 4s they suck for any car.
Old Oct 25, 2003 | 06:12 PM
internetautomar's Avatar
mod or sell?
Put in the correct NGK plug #.
If you don't know it do a search. I've posted it before
Old Oct 26, 2003 | 07:00 AM
blppt's Avatar
Thanks for all the help guys. I will look into the NGKs for the time being, though expensive as they are.
Old Oct 26, 2003 | 07:09 AM
mod or sell?
the VGs plugs are only about $2 ea they are definitely not expensive
Hondarydr
Dec 30, 2024 06:15 PM
tarun900
19
Dec 20, 2021 06:57 PM
Chebosto
Sep 11, 2002 05:36 AM
Cumalot
Feb 21, 2001 10:01 AM
