Transmission or Problems????
Old Oct 29, 2003 | 10:04 PM
barttexas's Avatar
[FONT=Times New Roman][SIZE=10]
I recently bought a used 1993 Maxima.
When you put the car into Drive, it takes a few seconds to catch, it doesn't catch right away.
The car also stalls, while driving.
Three days ago, I lost reverse. Reverse is Neutral and Neutral is 1st Gear.
What could be causing? Is the transmission going out? Or what could the problem be?
Old Oct 29, 2003 | 10:11 PM
Brad92SE's Avatar
The catching problem is a worn shifter bushing, its a cheap part. Is your car an se or gxe? If its an se the stalling could be a bad ignition coil. It could also be related to the MAF or TPS.
Old Oct 30, 2003 | 06:07 PM
barttexas's Avatar
It's a SE.
Old Oct 30, 2003 | 07:20 PM
Brad92SE's Avatar
It's a SE.
I had the stalling problem too, where it would just cut out for a second or two while driving. All I did was unplug the MAF harness from the sensor and smash down the female connectors a bit so it would fit tighter.
Old Oct 31, 2003 | 01:06 PM
eric93SE's Avatar
sounds like your shifter bushing need to be replaced. There are two of them, they usually break then fall off. So there will be a lot of play in the tranny cable. when driving the car can easily fall out of gear. One is located above a heat shield thats above the cat. convertor. The other is loated where the cable meets the tranny.
You should also replace the tranny fluid.
Old Nov 4, 2003 | 03:12 PM
barttexas's Avatar
Its neither one of the bushings. what else could it be? what happens when the torque converter breaks?
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
