1 fog light not working, please help
Old Nov 9, 2003 | 05:22 PM
ArcticDC5's Avatar
Yes, I know many of you would say the bulbs is blown out. This is not the case. After removing the fog light with the 10mm socket, after snapping one rusted bolt, I removed the lens and the inside is all rusted. I managed to get the old one out and put the new one in and plug the wire in. I tested it out and still does not light up. Do you think I need a whole new fog light housing or is there a seperate fuse/relay that would be the problem? Thanks.
Old Nov 9, 2003 | 05:39 PM
ghostmax's Avatar
well if the other light is working, it's probably not the fog relay or fuse. do the wires look corroded in any way? if not, i don't really have any other clues. good luck.
Old Nov 9, 2003 | 11:03 PM
rrrfoma's Avatar
First of all check if you get "ground" on your fog light (as you said - it is all rusted out - in this case just add a ground wire), then check if you have "power" (if not - the only option is to re-wire it).
There should be just one relay for both fog lights, right?
Old Nov 10, 2003 | 12:07 AM
nubiannupe's Avatar
OG Maxima.org Member
Yes, there IS only one relay. Have you tested the actual fog light harness plugging into the fog light itself? Test that for 12v using a DMM or testlight before you do anything else. All this removing the fog light housing is gonna do you NO good if you don't have power going to the light itself.
Also, you said the bulb isn't blown but you didn't say how you came by this decision. Did you check the filament in the bulb or swap it out with the working side or just apply power to it? Kinda unclear on that.
I'd suggest first testing the wiring, 12v as well as ground, then make SURE you have a working bulb (and "new" doesn't always mean "working").
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
