ignition relay == starter relay?
Old Nov 10, 2003 | 05:34 PM
gilley's Avatar
I need to replace my starter relay (flakey response). I can find no entry for a starter relay but all of the online parts places list an ignition relay.
same thing?
Old Nov 10, 2003 | 06:10 PM
internetautomar's Avatar
mod or sell?
same thing?
Not Generally speaking.
Pull a # off the old relay and run it through KEM's interchange and then maybe you'll have your answer
Old Nov 10, 2003 | 06:28 PM
-shock211-'s Avatar
there are 2 ignition relays (blue) and one starter/inhibitor relay (grey).
the ignition relays are inside the car and the starter relay is under the coolant reservoir.
Old Nov 10, 2003 | 07:01 PM
gilley's Avatar
I'll pull the part number and do the xref. Under the coolant reservoir??? I found mine on the sheetmetal of the left front strut area (just in front of the master cylinder...)... blue, wires running to the starter....
Old Nov 12, 2003 | 05:21 AM
-shock211-'s Avatar
the location might be different for people w/o abs apparently. mine is under the coolant reservoir in a box with other relays.
Old Nov 13, 2003 | 02:15 PM
gilley's Avatar
problem solved
Okay, to wrap this post up, I bought a $14 starter relay from NAPA, swapped it with the original and ALL of my intermittent starting problems are gone. 4 days and no issues at all.
I am soooo happy to have my car sort of back to normal, next, I need to swap out those Bosh plugs...
Old Nov 13, 2003 | 06:28 PM
bonzelite's Avatar
bosch
yes. the max does not like bosch for some reason. i tried the bosch 4's and one went bad fairly soon. i'm back to ngk.
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
maxima297
Sep 30, 2015 03:32 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
