FSTB installed, but got a quick question
Old Nov 14, 2003 | 09:51 PM
AscendantMax's Avatar
Got that fstb finally installed and man...car feels a lot different during a turn, etc. my question is, how hard does the bar have to "push" on the strut mounts? it's on there snug, but i can adjust it to have it push out more. thanks for any replies.
Old Nov 14, 2003 | 11:08 PM
Bman's Avatar
Congrats Fosgate. I don't know for certain if it's the "right" way, but seeing how the brace is supposed to keep the towers from bowing inwards, I fit mine very snugly. What I tell people is to adjust the length so that you almost have to push the bar towards the opposite tower to squeeze the bolt through. That way you get basically zero lash. It just seems the logical way to me and I think it's what I read at one time too...
HTH
Old Nov 14, 2003 | 11:35 PM
EdzMax's Avatar
At least u dont have the problem I have
Old Nov 15, 2003 | 04:14 PM
i guess i'll just leave them simply snug. seems to be doing its job though! i can only imagine what a full setup would feel like.
Old Nov 15, 2003 | 10:04 PM
jaguax's Avatar
Doesn't tightening the bolts push it all the way down?
Old Nov 15, 2003 | 10:13 PM
no not the strut bolts. it's the adjustable thingy on the end of the aluminum bar. if i twist it, it will push out (or pull in depending on direction of turn) on the two strut mounts.
Old Nov 17, 2003 | 09:50 AM
ADNY's Avatar
Which FSTB did u get?
I have been thinking about going in that direction with my max.
was wondering:
Did it take long to install(or is it a straight bolt on-less the snugging)
Which one did u go with
Do u have any other upgrades to your suspension/steering
I am assuming you like the"difference" it produces, cause u didnt say.
Could u describe where u feel it is most noticable?
AD
Old Nov 17, 2003 | 03:40 PM
my suspension is basically stock. i feel the most difference during turns at moderate speeds. the car doesn't seem to flex/twist as much now with the FSTB on. the install took about 15 minutes. i removed those 3 nuts on each strut tower, put in the brace end-mounts, adjust brace length and installed the aluminum bar. pretty simple.
Old Nov 17, 2003 | 03:50 PM
crazy4maxima's Avatar
yep just need i think its a 14 or 16mm socket.. and must be on level ground..
edzmax-yes i hear you bro 92=94 se have the damn Hose in the pass side
Old Nov 17, 2003 | 03:59 PM
yeah, it's 14 mm. those suckers are on pretty tight (least mine was) so a good length wrench would help. after u got the brace on, torque them down to 35 ft/lbs.
Old Nov 17, 2003 | 04:04 PM
please dont over torque them, if you break the bolts your due for some expensive repair..
Old Nov 17, 2003 | 05:00 PM
internetautomar's Avatar
mod or sell?
Y? they're only strut mount bolts. They come with the strut mounts easy as doing a strut.
Old Nov 17, 2003 | 05:02 PM
labor if you dont want to do it, like me
Old Nov 17, 2003 | 05:16 PM
mod or sell?
Heck it gives you a good excuse to upgrade your struts and springs
Old Nov 17, 2003 | 05:18 PM
mod or sell?
Oh yeah and to buy more parts from me!
JRod28
Dec 29, 2023 09:56 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
fulloboost
Sep 12, 2015 08:03 AM
classymax420
Aug 6, 2015 06:35 PM
