Power Steering Hose and Whinning Noise
Old Nov 18, 2003 | 10:57 AM
Noela's Avatar
Hi,
I replaced my power steering hose - which had been badly for almost 2 months today.
However, the car still makes the familiar whinning when the engine is idling and it gets worse as I accelerate.
The mechanic indicated that the noise is probably related to the fact that it had leaked so badly, and that it is not likely to go away.
Could this be right....? Any thoughts?
Noela
Old Nov 18, 2003 | 11:03 AM
internetautomar's Avatar
mod or sell?
Could be.
Did you replace the belts to?
Old Nov 18, 2003 | 11:08 AM
Jeff92se's Avatar
I'm needing a caw
PS pump went ******* up
Old Nov 18, 2003 | 11:24 AM
mod or sell?
He said *******
hehehehehehehe
Old Nov 18, 2003 | 11:28 AM
broncoguy's Avatar
Jeff's probably right...pumps don't like running without fluid for very long...
Old Nov 18, 2003 | 11:41 AM
mod or sell?
Did they flush the system too?
If they didn't you may be buying more than just a pump
Old Nov 18, 2003 | 12:47 PM
Noela's Avatar
thanks for your responses ...
sorrry about my ignorance but if you claim the pump went tittiees up - what does that mean... and is there anyway i can find out if indeed the ******* are up?
is it routine to flush the system too.... or it is up to the discretion of the mechanic; how expensive is it to flush the system?
cheers - Noela
Old Nov 18, 2003 | 12:53 PM
Jeff92se's Avatar
I'm needing a caw
It means it's dead, gone with the wind, **** down into the ground, 6 feet under, swimming with the fishes etc....
You probably ran it low on fluid and burnt it up. Buy a rebuilt one and replace it.
Old Nov 18, 2003 | 12:57 PM
mod or sell?
cheers - Noela
Mechanics discretion. ******* up means it failed or is going bad.
Old Nov 18, 2003 | 01:07 PM
Noela's Avatar
Thanks again, but then couldn't the mechanic have spotted this whiles changing the hose?
how expensive is it to fix (used parts and labor)?
and is this different from the rack (steering rack?) i hear the failed pump can affect the rack too.... is that right?
/tx - Noela
Old Nov 18, 2003 | 01:10 PM
Jeff92se's Avatar
I'm needing a caw
Ok I'm done here.
mod or sell?
/tx - Noela
Not neccessarily.
yes this is different from the rack and if done incorrectly can kill a rack too.
Shift_Flush
Old Nov 18, 2003 | 01:43 PM
Noela's Avatar
thanks.. how expensive is to replace the pump, assuming i'm using a used/rebuilt part...
and how long can i wait to fix it... given that I may not keep the car for more than one more year - it is currrently at about 270K miles.
/Noela
Old Nov 18, 2003 | 02:29 PM
mod or sell?
approx 1.5 hr labor depending on what labor guide they use. and which motor you have
Old Nov 18, 2003 | 02:38 PM
Noela's Avatar
thanks -- ohh, so the type of pump depends on the motor used -- mine is a 91 GXE -- i understand these could have either an electronically controlled pump or a mechanical one. how does one know --
the parts section of maxima.org quotes abut 70 for the mechanical, and about 200 for the electronic ..ahhh !
thanks again - you've been a great help -- Noela
Old Nov 18, 2003 | 04:16 PM
mod or sell?
With electric Control:
Without electric control
does that help?
Probably not
lowpost99
Oct 26, 2025 06:53 PM
MR2 T'd
Jul 9, 2021 05:06 AM
captchaos
Mar 15, 2016 12:18 PM
aminus21
Sep 12, 2015 04:53 PM
dcam0326
Sep 7, 2015 07:26 AM
