New Alternator
Old Nov 19, 2003 | 06:44 PM
nigfink's Avatar
New Alternator
I just put in a new alternator and battery, but my battery seems to keep dying. Is it possible that the alternator I got just isn't putting out enough to charge the batter when I run other electrical things? It seems as though when I drive at night, it won't start the next day. Sounds to me like the alternator isn't charging the battery properly. Is there anyway I could have put the alternator in incorrectly? It must be producing some power, because the car runs right after it is jump started.
Old Nov 19, 2003 | 07:03 PM
ljbrew001's Avatar
Check the voltage when charging. It should be ~14 Volts. If it is you probably have a bad battery or a bad connection to the battery.
internetautomar's Avatar
mod or sell?
Do a search, We have previuosly covered testing and diagnosing alternator failure.
Old Nov 23, 2003 | 01:01 AM
cspangg's Avatar
had the same problem, if the alternator checks good, check the + battery cable where it connects to the battery, there is a 2" jumper wire running along side the terminal block of the + cable, mine was broken.
TallTom
57
Oct 14, 2025 05:16 PM
