Power antenna question.
Old Nov 19, 2003 | 10:31 PM
barrylaud's Avatar
I am sure my car is like a lot of yours, the power antenna does not work. I have seen replacement antenna masts on EBAY. Anyone try to replace the mast only??? I can hear the power motor running, but of course the mast is stuck.
Or would I be better off replacing the entire unit?
Old Nov 20, 2003 | 01:27 AM
davebond007's Avatar
If the motor runs then its fine. You probably just need to replace the antenna mast. How it works is there is a piece of plastic line inside with a bunch of notches on it that the motor uses to push and pull the antenna up and down. If the motor works fine, then its probably just the notches are worn down.
New mast is like $36 at the dealer. If that doesn't work, then I'd just unplug the power to the antenna motor and not have the antenna going up and down. You can crimp the joints in the antenna so you can keep it up to still maintain reception, but it's still connected to the stereo.
Old Nov 20, 2003 | 04:20 AM
internetautomar's Avatar
mod or sell?
or if you really want a power antennae and your is fried you should be able to pick up an aftermarket one for about $40
Old Nov 20, 2003 | 08:57 PM
barrylaud's Avatar
Where can you get a power antenna assy for $40?
Old Nov 20, 2003 | 09:33 PM
«§»Craig B«§»'s Avatar
www.4dsc.com/articles
Old Nov 20, 2003 | 11:54 PM
jaguax's Avatar
Just search ebay for "Maxima Antenna"
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2443478577
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2443642950
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2444026467
Old Nov 21, 2003 | 08:35 PM
barrylaud's Avatar
thanks you gentlemen.
Old Nov 22, 2003 | 08:43 AM
rrrfoma's Avatar
ha-ha!!! I did - it died in one season (a high quality Hirschmann one)
Old Nov 22, 2003 | 11:04 AM
99SEL4ME's Avatar
I had the same problem, could hear the motor running, but the mast stayed up. Got a Nissan mast for $27. from Courtesy. Works LFN.
chisam14
Nov 6, 2018 08:56 PM
doctorpullit
Mar 29, 2016 11:08 AM
leatherneck
Sep 30, 2015 09:16 PM
