Tokico Strut Insert Help
Old Nov 23, 2003 | 04:36 PM
Jack.'s Avatar
Right now i'm right in the middle of my rear suspsension and i need some help. I took out the gland packing o-ring and the original strut. I just put in the tokico cartridge and the o-ring surrounding it, but now the gland packing won't go down far enough to thread. Is there something I did wrong?
Old Nov 23, 2003 | 05:36 PM
rrrfoma's Avatar
"factory" gland packing wouldn't fit ... look inside of the package - aftermarket gland packings must come with your new struts (if not ... you'll not be able to finish the job ... sorry)
Old Nov 23, 2003 | 06:01 PM
MaDMaX024's Avatar
i didnt use the metal O-ring, everything seems to be ok so far. just use the new gland nut (thats what i did with the GR2's that i installed last year along with the tokicos i installed about 2 months ago) and put it back together the way it came out.
Old Nov 24, 2003 | 07:45 AM
snowman2155's Avatar
I found that out too when I did mine. Good luck.
Old Nov 25, 2003 | 12:52 AM
Jack.'s Avatar
Yeh turned out that a couple of my friends that were helping me handed me the cartridge, and didn't realize that there was the new flange...
However, I have a new problem. I finished the front and rear suspension and as i test drove it, I hear a popping noise coming from the rear right assembly. We get out and inspect the problem and while we push up and down on the rear bumber we here it again.
Turns out it's coming from the spring. The spring is scrunched up near the top and it's overlapping one of the other coils everytime it feels anything major. The center bolt is to standard torque settings. Could the spring have possibly turned out of it's grovescausing it to compress higher?
Old Nov 25, 2003 | 06:57 AM
internetautomar's Avatar
mod or sell?
Is it installed right side up?
Old Nov 25, 2003 | 07:03 AM
Matt93SE's Avatar
STFU n00b!
Sounds like you need to pull that side of, remove and reinstall the spring. it may not be seated properly.
Old Nov 26, 2003 | 05:55 AM
Jack.'s Avatar
Lol, yes it's installed right side up. I felt around with my fingers to see if the bottom was in the propper grove of the seat.. Im getting the car an allignment today i'll see if they can have a look.
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
