Testing the 02 sensor
Old Nov 26, 2003 | 08:08 AM
chris92's Avatar
I suspect my 02 sensor is giving me problems ( see http://forums.maxima.org/showthread.php?t=262533).
Does anyone know how to test the 02 sensor on a '92 VG motor? I did the self-diagnostic check, and no codes were shown, but I'd like to check the 02 output voltage while I drive and I was wondering which wires to test, my manual is little help.
Thanks.
Old Nov 26, 2003 | 08:33 AM
internetautomar's Avatar
mod or sell?
If it's got over 60k on it change it! period
Old Nov 26, 2003 | 10:27 AM
eric93SE's Avatar
I concur!
REPLACE IT
Old Nov 26, 2003 | 10:33 AM
chris92's Avatar
Originally Posted by eric93SE
I concur!
REPLACE IT
Replace at 50,000 kms (35,000 miles)?
I guess I thought I'd get more out of it than that.
Old Nov 26, 2003 | 10:34 AM
mod or sell?
60k miles not KM
Old Nov 26, 2003 | 11:08 AM
eric93SE's Avatar
Well it can go bad that soon. It has a lot to do with how well your engine is running. If its producing a lot of carbon, then the sensor will foul up quickly. So you can consider doing a full tune up (cap/rotor/plugs/wires). It could also be caused by a leaking fuel injector, causing a cylinder to run rich and then unburned hydrocarbons will be in the exhaust stream (then plugging the 02 sensor).
Old Nov 26, 2003 | 11:20 AM
Jeff92se's Avatar
I'm needing a caw
Read this and keep this link for reference every day of your natural life
http://www.cybrrpartspro.com/Chilton...61CH04_15.html
Old Nov 26, 2003 | 11:30 AM
Nismo87SE's Avatar
To check the o2 sensor put the ecu in diagnostic mode I and start the engine. I believe the CEL will blink each time the o2 sensor goes from rich to lean, if it doesn't toggle then its bad.
EDIT: Tree'd by Jeff
Old Nov 28, 2003 | 10:23 PM
rrrfoma's Avatar
O2 sensor tool
I'm a bit confused ... - just received a bosch O2 sensor in the mail and to my big surprise 7/8" O2 sensor tool is too big. If fact bosch one is 17mm ...
The question is ... which socket do I need to unscrew a factory one?
Is it 7/8"? ... or 17mm? It would nice to know ahead - before I get under the car
Thanks!
Old Nov 29, 2003 | 03:57 PM
mod or sell?
The nissan o2 is smaller than standard o2s by a considerable margin. so I'd suggest either modifying a deep socket with a slot up the side.
or just use a wrench that fits on the new one.
Old Nov 29, 2003 | 04:16 PM
rrrfoma's Avatar
I decided to settle with a 17mm crow's foot wrench
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
rbaker100
Sep 25, 2015 07:52 PM
msellas
Sep 23, 2015 09:16 PM
ac max 92
Sep 17, 2015 07:35 AM
