5spd conversion
Old Dec 2, 2003 | 05:53 PM
BML94GXE's Avatar
Maxima Withdrawl is real
5spd conversion
I cant search so then i was looking manually but have given up. can anyone give me the link to a fourm that says what i need parts wise to convert my auto to 5spd? thanks
Old Dec 2, 2003 | 06:02 PM
MrGone's Avatar
ok, I'll probably forget some things, but heres the gist...
-tranny
-shift linkage
-shifter
-clutch master and slave cylinders
-clutch pedal assembly
-5spd brake pedal
-hydraulic lines/bleeder valves/etc
-I forget which axles are the same and which change. I believe you can reuse the passanger axle?
-transmission mounts
-rewire neutral/park switch to go to the clutch pedal switch
-flywheel (I believe Matt93se is now sold out of VG fidanza's ... Jeff92se might be able to get one, he sells the VQ fidanza's).
-clutch
-the bolts that hold the flywheel to the crank. The ones that come on an auto arent long enough (edit: well there probably long enough, but the 5spd ones are longer because the flex plate is about 2mm thick, while the flywheel was atleast a cm thick)
-gear oil
-loc-tite
-transmission seals
-shift boot/surrounding bezel (for the interior of the car)
I think thats about it.
Old Dec 2, 2003 | 06:09 PM
internetautomar's Avatar
mod or sell?
Short Version:
Get a Complete Donor Car.
And start swapping
Old Dec 2, 2003 | 07:59 PM
KLoWnPR109's Avatar
You can use your current axles
Old Dec 2, 2003 | 08:03 PM
MrGone's Avatar
like you would know
Old Dec 2, 2003 | 08:35 PM
subs1000w's Avatar
klowns right you can use your curren axles
your need the ears or mounts that bolt the trany to the engine they are different between the auto and 5spd
you could put a manual brake pedal in but we just got the manual brake pedal boot and sawzalled the auto pedal and put the boot on much much much easier
you also need a template or some dimentions to know where to drill holles for the slave cylinder
Old Dec 2, 2003 | 08:58 PM
dmontzsta's Avatar
Ford Only.
5 speed conversion? haha, never...it cannot be done.
Old Dec 2, 2003 | 09:05 PM
Maximan190's Avatar
yes
get a whole parts car it helps
Old Dec 2, 2003 | 09:13 PM
harrymay's Avatar
thats something id like to do, but not on the car i have now, the vg isnt worth the hassle, i could understand an auto se 92+ doin a swap on it to get full potential
Old Dec 2, 2003 | 09:27 PM
KLoWnPR109's Avatar
So true, so true
Old Dec 2, 2003 | 09:29 PM
MrGone's Avatar
So true, so true
funny everytime I read it
Old Dec 2, 2003 | 10:49 PM
mtcookson's Avatar
turbo vg is worth it
actually, i need to swap in a 92-94 5-speed with vlsd. i'm having traction issues.
Old Dec 3, 2003 | 05:52 AM
mod or sell?
Traction, Isn't that what you get in the hospital after you lose it on the street?
Old Dec 3, 2003 | 07:45 AM
shoult's Avatar
You need a donor car sitting right next to your patient. That way you don't get peice mealed for each and every part you need. Especially all those little things no-one ever thinks off until they're almost done and then... DANG! I Need a Heamerdorf Ring!
Old Dec 3, 2003 | 08:03 AM
KLoWnPR109's Avatar
A donor car isn't exactly necessary, but IMO, it's the only way to go. You can see exactly how everything should fit up after everything is said and done.
You can go purchasing piece by piece, but buying a parts car will save a TON of hassle
Old Dec 3, 2003 | 08:15 AM
mod or sell?
Oh dam I forgot that little e-clip and bushing on the brake pedal. it's 12 pm and I need the car for work tomorrow at 6 am
dealers closed now
I'm f-ed
Get a donor car COMPLETE
Old Dec 3, 2003 | 08:34 AM
subs1000w's Avatar
a donor car would be the most convienent way but the one i help with we made about 20 trips a 2 diferent junk yards. parts were not that much you guys no the rule anything that fits in a pocket or toolbox is free and most of the little stuff did.
total cost was about 300$ but we used the clutch from the donor car, rebiult the master cylinder and bought a new slave cyinder
Old Dec 3, 2003 | 11:09 AM
MrGone's Avatar
a donor car will also be alot cheaper in the long run than sourcing out parts and stuff like that, not to mention easier.
Old Dec 3, 2003 | 11:21 AM
shoult's Avatar
Heck with a donor car and eBay you can come out ahead on a project like that. Everything you don't use (once your SURE you're done) gets sold!
Anybody ever read Grassroots Motorsports for their $2001 challenge?
Old Dec 3, 2003 | 11:25 AM
todamax's Avatar
I've got a donor car...
Jeff92se's Avatar
I'm needing a caw
Bah. I have all the swap parts available from my 5-sp VE parts car sitting in the garage. Everything but the tranny itself. I'd sell it for about $150 shipped.
Old Dec 3, 2003 | 11:36 AM
mod or sell?
only got the 3/03 issue couldn't afford a subscription
But they do offer a free sample issue
Old Dec 3, 2003 | 12:05 PM
MrGone's Avatar
whats this Grassroots Motorsports and this $2001 Challenge you speak of? sounds interesting....
Old Dec 3, 2003 | 12:08 PM
mod or sell?
http://www.grmotorsports.com/
check it out!
Old Dec 3, 2003 | 12:09 PM
MrGone's Avatar
oh this is that magizine for normal people with normal budgets and doing 'normal' projects.
hmmm whats this $2004 kumho challenge?
Old Dec 3, 2003 | 12:12 PM
mod or sell?
dunno but sounds like fun to me especially when my car cost me only $200
Old Dec 3, 2003 | 12:13 PM
Jeff92se's Avatar
I'm needing a caw
Ah, can you two get MORE OT? Use email or pm thanks
Old Dec 3, 2003 | 12:17 PM
mod or sell?
Jealous, Jeff?
BTW Shoult Started it!
Old Dec 3, 2003 | 02:19 PM
ChrisCheezer's Avatar
jeff92se
jeff-- empty your PM's
Old Dec 3, 2003 | 05:31 PM
hard tranny ECU question: If im doing a 5 spd conv. and the parts are from a 92se and i have a 90se will everything bolt up? and work?
-like the tranny ecu, and harness. can i, Take out my old tranny ecu and plug in the 5spd ecu and then plug my old harness into all the 5spd parts?
thanx in advance
thanx in advance
Old Dec 3, 2003 | 05:54 PM
mod or sell?
Keep your ECU it should be fine otherwise use the 90s ecu not 92 as 92 is a VE motor not VG like you have
Old Dec 3, 2003 | 06:25 PM
vg is slow enough to keep me alive
yay!
can anyone 2nd that?
Old Dec 3, 2003 | 07:40 PM
MrGone's Avatar
VE ECU no work with VG
I believe all VG's had VI's anyway, so there is no need to swap VG ECU's.
Old Dec 3, 2003 | 07:45 PM
BML94GXE's Avatar
alright so since im taking my 94 auto out and putting in hopefully a 92 - 94 se stick in, do i need a 90 stick ecu then? also if i was to pull the parts from a maxima with a vg engine, then do i still have to replace as much stuff, like those longer bolts, etc?
Old Dec 3, 2003 | 07:51 PM
subs1000w's Avatar
if you use a 92 - 94 se 5spd tranny you will need different axles and spindles for your gxe
either way you dont need to change your ecu
if you pull the tranny from a 89-91 vg 5spd you wont need to change axles or spindles
what longer bolts are you talking about
Old Dec 3, 2003 | 09:16 PM
im guessing its the same if i have a 90 SE?.. the axles and spindles
Calabar
Oct 5, 2015 09:57 PM
ef9
Oct 4, 2015 08:43 AM
kjlouis
Sep 14, 2015 11:22 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Hdnseek
Sep 9, 2015 05:55 AM
