car won't start after disconnecting VTC
Old Dec 4, 2003 | 09:34 PM
Nmax92's Avatar
I need help from the VTC experts. When i disconnect my VTC and try to start my
car, It won't start at all!! It will only start if the VTC is connected. This is a real mystery isn't it?
Old Dec 5, 2003 | 08:51 AM
Lordrandall's Avatar
You don't want to disconnect them, you want to ground them to keep them quiet.
Old Dec 5, 2003 | 10:17 AM
Nmax92's Avatar
I tried grounding them and got the same result. When I turn the key, the only thing that happens is the lights on the dash come on and thats it. The engine won't even make a sound, it's completely silent.
Old Dec 5, 2003 | 10:24 AM
internetautomar's Avatar
mod or sell?
If you have them normally connected the car runs fine?
Old Dec 5, 2003 | 10:30 AM
cneary812's Avatar
make sure that you tapped into the right wire I beleive it is the yellow and black one but I can't remember check the stickies...
does it start ok when you connect it??? If they are not ticking don't mess with the VTC's
Old Dec 5, 2003 | 10:40 AM
blackandwhite's Avatar
To them I'm like an idol
My car did this a couple of times. Right after I would reconnect my grounding plug, the car would act as if it was dead. It doesn't do it anymore. In fact, it hasn't done it since I replaced my starter. Not to say that that is the answer, but I have seen what you are talking about.
Old Dec 5, 2003 | 05:38 PM
Nmax92's Avatar
yep, except for the ticking sound. I forgot to add, when I first start the car, its very quiet. The ticking gradually start to get louder as the car warms up. From there it's ticking heaven until I turn off the car.
Old Dec 5, 2003 | 05:39 PM
Nmax92's Avatar
Is there any way to test the started to see if it's really the problem in my car?
where is the starter located? I'm pretty competent around an engine, but I never looked for my starter.
Old Dec 5, 2003 | 05:43 PM
Gjohnson's Avatar
Well, I'm trying to determine if my VTC's are going bad also. My car is quiet at start up and remains quiet unless it idles for over a minute or so. (like when I'm in line at a drive thru picking up food.) But if I put the car in neuteral and rev the engine, it go's away. (until it sets for another 30 seconds or so.)
Old Dec 5, 2003 | 06:51 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
bad vtcs !!!! bad !!!! hopefully my mess ups fixed soon !
Old Dec 6, 2003 | 01:00 PM
cneary812's Avatar
mine started out exactly like you are describing and progressively got worse. You can ground them and they will stop ticking but you may get some funky idoling like I did or you can just deal with the ticking, it won't hurt anything. Or you can rebuild or replace them.
Another thing that causes ticking at startup could be broken exhaust manifold studs, so check for broken studs as well. But your problem is VTC's
Old Dec 11, 2003 | 10:20 PM
barrylaud's Avatar
I have had my grounded for over 15,000 miles. I noticed a little top-end power-loss, and a little poorer gas mileage.. But at least people don't ask how I got a deisel engine in my max anymore!!
Old Dec 12, 2003 | 05:48 AM
cneary812's Avatar
all the perks of a diesel except the low end torque, and the better mileage, and the higher compression, and the efficinecy... and... ok it just sounds like a diesel.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
BobMax
Aug 15, 2015 12:35 PM
