Got a lighting question for you guys
Old Feb 26, 2001 | 09:18 AM
MaximumTM
I have an 89' Maxima and my front right "Passenger Side" headlight has gone out...but only the low beams not the highs...its not the bulb...nor the wiring harness. So it concludes that it is most likely the lowbeam wiring that leads back into the connection box. So heres my question:
A. Has anybody ever had this happen to them?
B. If you have or know whats wrong, am I right...or is there something else, and how do I do it?
Thanks guys
Old Feb 26, 2001 | 01:53 PM
Tom's Avatar
Tom
Check the bulb
Same thing happened to me when I had a Honda many years ago. What you can do to check is to swap the headlight bulbs left and right. If your driver side headlight goes out, you know it's the bulb.
Old Feb 26, 2001 | 02:58 PM
MaximumTM
Tried that already
I tried that one already....even replaced them both just too double check. Didn't work...switched...switched wiring harnesses...none of that worked. Its got to be something else.
Old Feb 26, 2001 | 06:56 PM
Tom's Avatar
Tom
Did you
Did you check the headlight fuse?
Old Feb 26, 2001 | 10:00 PM
block's Avatar
same thing happened to me last week, but i just assumed it was a filiment in the bulb burned out. I replaced my lights with the bimmers and now it all works fine. check the fuse
Old Feb 27, 2001 | 06:23 AM
MaximumTM
Fuse...Check
Yeah, I already thought about that one. Infact I checked all of my fuses (alot of them) and none of them were blown or fried. I simply replaced the two front headlight fuses just to be safe but that was the problem either.
Old Feb 27, 2001 | 11:00 PM
bigjay's Avatar
simple light test
this is not as hard as you are makeing it, if you dont have a light tester ,get one(3-4 dollars,worth the investment)turn on low beam and check the current going threw the wire. youll get one of 2 results, light on and light off(dont forget to check the ground with a constant power source, your light tester manual will explain in more detail). If the light is on follow the wire toward the light untill the light does not light any more and then you will have found your problem. If the light is off, follow the wire in the opposite dirrection away from the light untill it lights and then you have your short or fuse or fuseablelink(post fusebox). dont forget to tape wire after probing jagoff
JMag90
Aug 25, 2015 09:17 AM
spidgeon
Aug 18, 2015 05:46 AM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
