Alarm Question
Alarm Question
Hey all needed to know if any 3 rd geners out there have installed a aftermarket alarm in their max? I have a good idea but needed a second opinion about install a rear trunk switch so i will have 5 zones instead the tradition of 4 zones(all doors) I wanted to splice into one of the door pins and run that wire to the trunks light so. If the trunk is opened and the alarm is on the alarm will go off!! Let me know all!!!
Originally Posted by gowirelessnj
if i open my trunk with the alarm then the factory alarm goes off.
sorry maybe i wasnt very clear, I am talking about a aftermarket alarm, not the OEM alarm that comes with the car. What i am asking is the same concept as our factory alarm and the hood pin switch. Say if u turn on the factory alarm and the hood is forced open or one of the car doors is open then the lights flash and the horn honks. But I just want to add a trunk switch on my viper alarm.
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
when you open the trunk, do you see lights coming on inside?
now ... why would you need to install an additional switch???
just use an existing one ...
or you could just wire it to the wire that tells the tunk is open on the OEm alarm
http://www.geocities.com/craigbrace/
craigbrace has a wiring dighram that might help you out
Unclejunebug
04-02-2016 05:42 AM
Stagnet04
10-11-2015 08:16 PM
