16" or 17"-quagmire????
Greetings fellow maximans...!
The search function isn't working so if my question has been asked and answered, I apologise.
I'm looking to get new rims for my 92 max and i'm debating btw 16" and 17".
I'd like to get a 16" wheel, preferably the Eagle 077 5 spoke, but it has an 8" width and according to my tire company, thats a tad bit too wide, so if anyone has an 8 inch wheel and has any info on recommendations for installation nad tires , please hook a brother up.
Plus any advice on 17" possibilities and if what your experience is with 17's.
Thanks!!
mrgoogs.
Thanks!!
mrgoogs.
Thanks!!
mrgoogs.
Thanks!!
mrgoogs.
i have a friend i work with that is running 17's on an altima, i think theyre enkei sumthings, theyre real lite and look cool. i would get 17's but im a short guy so id have to make my rims taller than me, 60" rims dawg
Most people like to go with 17's, but Matt93SE ran with 16's for the longest time, and one other thing to consider is the peer pressure people will give you to lower the car if you go with 17's. With 16's the wheel gap isn't as noticable (depends on wheel styling too) but with 17's it usually is.
All other things being equal, 16" wheels and tires will be lighter than 17" ones and you could notice a performance diffference. If you can afford to, get lightweight wheels.
If you're mainly doing this for looks, offsets aren't as critical because you can just use a narrower tire, but if you want big tires like Madmax024's, then you'll need something between +35 and +30. (His Eagle 077's are +38 by the way, I don't know what the 16" model's offset is.) I believe 225 tires with some narrower wheels also work with broader offsets too (in the +40's).
i'd go 17's to clear BIG brakes
I got 17s, with 37PSI in the front and 35PSI in the rear and the car seems to be a little bouncy sometimes. Is that normal cuz if I lowered it to factory spec at 29, they look really flat?
