Trunk Carpet....
Old Jan 22, 2004 | 04:26 PM
Iron_Curtain's Avatar
Trunk Carpet....
I'm making a custom trunk for my 91 SE Max. Anyone know where I can get the grayish carpet thats in the trunk? I want stuff that looks exactly the same as the stock stuff. If anyone knows, post a reply. Thanks
Old Jan 22, 2004 | 05:20 PM
internetautomar's Avatar
mod or sell?
Have you checked at your local stereo shop?
they have alot of carpets for subboxes that may be close to what you're looking for.
or I could always sell you some carpet too.
Old Jan 22, 2004 | 05:35 PM
Brandon90gxe's Avatar
stereo shops
Old Jan 22, 2004 | 07:58 PM
-shock211-'s Avatar
sell-*****
Old Jan 22, 2004 | 08:02 PM
Alright thanks fellas. I need to go there tommorow to buy 4 guage wire anyhow, so ill check with them. Thanks.
Old Jan 22, 2004 | 10:16 PM
harrymay's Avatar
im gonna replace my carpet, hopefully something with a flowery print. then im gonna wall paper all of my vinyl with pinstripes.
oh can anyone answer me this. is there a hole of some sort in the trunk, coz i looked under my wheel, and there was a water puddle, and my under board and carpet are wet
Old Jan 22, 2004 | 11:11 PM
lophix's Avatar
uh ok...get that cleaned and dried out fast. must be the weather stripping (rubber stuff) that's torn.
I hope you're joking about the flowery print thingy and wall paper and all....talk about straight eye for the queer maxima guy...
Old Jan 23, 2004 | 06:18 AM
mod or sell?
Originally Posted by -shock211-
sell-*****
Man's gotta make a living!
Old Jan 23, 2004 | 11:46 AM
harrymay's Avatar
all the weather stripping is fine, its coming from under the car. in the spare tire well it is practically turning into a well, everything inside the trunk, like my subs and my other stuff is fine
Old Jan 23, 2004 | 10:32 PM
Golden Ice's Avatar
ok, I'll bet you have a leak in the spare tire well, perhaps from a hole that was drilled in it?..take everything out, spare included, and examine the entire compartment for holes..probably going to be on the side somwhere, or the water should just run back out..but check the drain plugs and such..if all else fails, pull the drain plugs out, take out all the carpet, and all that junk, and spray the whole trunk down with rubberized undercoating (yes, on the inside of the trunk..), and leave the lid open for a full day to let it air out..then leave it open whenever you can for about a week after that..if its going to be dry, and you can't leave the trunk lid open, leave 2 or more of the windows down a little bit....then, after that, you can stick some dynamat or somthing on all the walls...get your vibration dampening/acoustic treatment and your waterproofing done at the same time..water used to collect in my spare tire well, but it was because I didn't seal around one of my trailer hitch bolts thoroughly..
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
lux97Max
Sep 14, 2015 07:07 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
