Calling all those with Fidanzas and Excedys...
So yeah, pulling out of a parking lot today after school and had to move in a hurry. Next thing I know, i'm hitting the rev limiter and i've barely pulled out. Looked out front to see not tire smoke but clutch smoke... ![Frown](https://maxima.org/forums/images/smilies/frown.gif)
First time it's ever happened and I haven't abused the clutch (maybe 5 drag runs...). How much for the package of Excedy and Fidanza? For comparison, how much for OEM? Oh, this happens just before i have to make a 1500 mile trip...
![goofy](https://maxima.org/forums/images/smilies/goof.gif)
Buy the Fidanza from me, and I think I can still get you an ACT for a pretty decent price. I'll have to check with my supplier, but I think a little over $300 for the ACT..
that's going to be the best you can get, unless you go with an Exedy off ebay or something.
Go with Matt and support an org member, I bought my flywheel from him and as far as the ACT $320 shipped is the best price I got when I bought mine.
J, you forgot to mention from where. Stillen believe it or not, $320.00 shipped and its a great clutch I've had it for 6,000 miles and no problems and N34JZ likes it also. 1-800-576-2833 ext. 139 James @ Stillen.
i would love to but I don't know it my father would. $350 bucks is quite alot for a flywheel... How much for an OEM total replacement?
you could probably get a LUK clutch for about 150 or go with the exedy on ebay for around $100 I think, then just have the tranny shop resurface and lighten your flywheel. anything else your gonna have to pay to play.
It's spelled Exedy but said Ex-city (thats just the easiest way to type it out... plus I just woke up).
Try to make the trip then replace it if you can.
And flywheel, try to get him to buy it as part of Labor
or just say yours has been warped from heat from the clutch slipping (lol).
There is a group deal as well.
You know if you wait until you get home I'll help out... but I might not drain the gear oil before I start yanking on the axles
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
![king](https://maxima.org/forums/images/smilies/king.gif)
I am a Direct Dealer for Daikin (O.E.M. to Nissan) /Exedy Racing Clutch If you Need A Good Price on a Clutch and Flywheel You can give me a call i have sold many clutches on this Site you can look at my Feed Back. you can also look at the Daikin/Exedy Site to see who a Dealer is http://www.daikin-clutch.com/distributors/index.shtml Look under New York name of my Company i is Direct Trans Parts http://www.mitsubishigraveyard.com/direct.html
types of clutches
Single Plate Organic:
EXEDY Racing clutches with organic friction materials use only premium friction materials that are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines.
The driveability will be like a stock clutch. Pedal efforts will be higher because of the higher clamp loads. All of our clutch discs have high capacity spring center dampers to reduce the drive train shock and impact. For Purchase information Please Click Here:http://www.mitsubishigraveyard.com/direct.html
Single Plate Cerametallic:
EXEDY cerametallic clutches are designed to handle the abuse of high power modified engines. Our cerametallic friction material can handle much more slippage than stock type disc assemblies without slipping and fading.
All EXEDY cerametallic clutch discs have spring center dampers to reduce the impact and shock loads put into the drive train. This protects the transmission and the rest of the drive line system.
We offer two types of cerametallic discs -normal thickness and reduced thickness.
The reduced thickness (thin cerametallic) discs offer greatly reduced inertia to improve shift efforts, make for faster shifting, and improve synchro durability. These discs are approximately 1/2 the thickness of a stock disc.
The normal thickness (thick cerametallic) discs have better heat capacity and therefore better durability in demanding applications such as all wheel drive. Even with the normal thickness, our three puck cerametallic discs still typically have less inertia than a stock disc.
With any cerametallic clutch system, there will be some compromise of start up driveability as compared to a stock clutch (chatter on light throttle, low rpm start up). This characteristic is generally felt to be acceptable in modified performance cars. Drivers of cerametallic clutches on the street should be warned not to "ride the clutch" to try to reduce the chatter as this will greatly increase the wear. For Purchase information Please Click Here: http://www.mitsubishigraveyard.com/direct.html
Cerametallic Thick Cerametallic Thin
Racing Flywheels:
EXEDY Racing Flywheels are made from solid one-piece billet chrome moly steel or chrome moly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel which has the possibilities of separating from the flywheel. This could cause the flywheel to explode due to two different expansion coefficients (aluminum flywheel pressed on steel ring gear). EXEDY steel billet and forged steel flywheels have passed engineering tests to 15,000 rpm. They are guaranteed to be explosion proof at the said rpm. For Purchase information Please Click Here:http://www.mitsubishigraveyard.com/direct.html
types of clutches
Racing Flywheels:
i have the fidanza and exedy stage 1
the clutch sucks, however maybe its just mine..
it grips great but im betting the pressure plate is shot (and 2 mechanics agree on this problem) because it is really stiff getting into gear and the pedal is very hard. I had it put in only about 4 months ago![Roll Eyes (Sarcastic)](https://maxima.org/forums/images/smilies/rolleyes.gif)
but as for ACT, ive driven 3 VE 5spds with ACT and i liked the way they felt
![wall](https://maxima.org/forums/images/smilies/peepwall.gif)
but as for ACT, ive driven 3 VE 5spds with ACT and i liked the way they felt![wall](https://maxima.org/forums/images/smilies/peepwall.gif)
![GrinNo](https://maxima.org/forums/images/smilies/grin_no.gif)
Originally Posted by MrGone
:bann ed: You couldn't pry my Exedy from my cold dead fingers.
thanks Izzy
![Wavey](https://maxima.org/forums/images/smilies/wavey.gif)
![kiss](https://maxima.org/forums/images/smilies/kiss.gif)
yeah you lucked out on my loss...
![lamer](https://maxima.org/forums/images/smilies/lamer.gif)
no problems getting into gears (going up, downshifting into 1 can be hard if I'm going to fast, but thats a tranny issue).
Pedal Feel: Well I love it, it pushes back on your foot, but doesnt really take alot of effort to push down on. I say the part about it pushing back on your foot because my Dad's 2000 SE 5spd had his clutch replaced about 2 weeks or so before I did mine, and he used an OE clutch (not sure what brand since he decided to take it to a shop) and his is hard to drive in the sense that when your engaging the clutch the pedal doesnt really push on your foot so you cant really get a good fell for it.
When Jeff92se drove my car he said it was alot easier to push on the pedal than his ACT was. I forget the difference between mine and Davebond007's, I think mine was alittle harder to push down on, but I think he was more impressed with the clutches grip.
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Jeff? Hurry up.
tried double clutching, doesnt really work to well with 1st gear. ![Frown](https://maxima.org/forums/images/smilies/frown.gif)
Thats right, I remember now, yours wasnt that bad though, I just focus more on the engage points more. Besides the only time I drove your car was before the dyno, while you've driven my car alot more (oh yeah, I let you borrow it that one time). Btw, 180*s and such are a lot easier with a aftermarket RSB
![ThumbsUp](https://maxima.org/forums/images/smilies/thumbsup.gif)
Give Me a Call i will put you on the phone with Daikin/exedy and go over your problem with them and lets see if its a slave / master or presure plate ? i am on long island
http://www.mitsubishigraveyard.com/direct.html[/url]
Is your clutch slipping now? I slipped my clutch pretty bad once but once it cooled down, it was fine. Just don't make a habit of it.
Didn't you just go though clutch class at UTI? You should know this!
You don't "need" a Fidanza but it's nice to have. You don't "need" an ACT if you don't go forced induction. A REAL OEM is pretty good. Of course the ACT would be all you would need for any future mod. IMHO, either OEM or ACT. I don't have enough experience to recommend others.
Maybe I can drive Mr. Gone's car again.![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
pluss..... whats the reliabilty? I'm looking for something that will last me some time.
Originally Posted by D-Sta
Are those three VE's in your sig, I told you from the beginning to get ACT. ![GrinNo](https://maxima.org/forums/images/smilies/grin_no.gif)
![Nervous](https://maxima.org/forums/images/smilies/nervous.gif)
nice sig, my rims now have the SEL finish too
![Cool](https://maxima.org/forums/images/smilies/cool.gif)
well, heres the story Jeff... no ACT, no OEM, exedys on ebay are 100 bux. I don't want ACT due to hugeginormous pressure plate that (for me) is not needed. A fidanza would only happen if my fly is too bad to resurface. Usually, one doesn't resurfece a flywheel twice.
I haven't driven it since then so I'll see later today
OEM is expensive... internetautomar wants 160 for his OEM clutches..... no offence man, but I'm not paying. 100 for an excedy sounds good. There's tons of em, either that, or i'll still look around. Ebay is just an option thats looking good.
That's fine Anton. Just make sure you know what you are getting. I've driven Shawn's car with the Exedy. It seems okay. But then again, I didn't rip on it either. But I can tell you, the pressure plate is NOTHING like the ACT. I've seen ratings here that state the Exedy(whatever version) at 33% over stock and the ACT at 39% over stock. From what I feel with the pedal feel inbetween the two, that is waaaayy off. There's no way those two kits could be within 3% of each other.
Ask Internetautomar about Daikan make of clutches. Also another good brand that is/or used to be the oem for Nissan/Datsun.
well, i don't want a firm clutch pedal especially in Seattle where traffic sucks. I've tried an ACT in my buddies 240 (fun car, btw) and it was too much effort for traffic. held nice, but still too much clutch effort.
My estimate. From stock, it's about 50% more effort. Which isn't that much IMHO. It's definately more effort don't get me wrong but nothing too bad. I drove it back and forth to work and that's rush hour commute stuff. No problems. I would tend to leave bigger gaps in traffic to avoid pushing the clutch all the time but again no biggie.
Just in my humble opinion, I don't see any stock clutch holding anything with nos/sc/turbo. At least not with full on hard shifts. I'd like to see something inbetween stock and the ACT for PP pressure though. But there isn't really.
Originally Posted by KLoWnPR109
Jeff, is the ACT that much more effort?
look up Daikin Web site i am a Distributors Listed. Who else can say that ??
What about the part where Exedy's stage 1 and stage 2 use the same pressure plates. I thought it was the disc material that was mainly responsible for clutches strenght or ability to grip?
i think both material and amount of pressure play a role in how much power the clutch will hold. more than likely the organic clutches are barely different than the oem clutch material but they use a stronger pressure plate for more grip... i could be wrong though.
The ACT street setup uses a stock or near stock disc and a higher rated PP to get more grip.
Think of it this way. Brakes. The PP is like the caliper. It supplies the force. the disc is like the brake pads. They have to be able to withstand the heat/pressure the PP/Caliper is appling to the flywheel/rotor.
![frosty](https://maxima.org/forums/images/smilies/frosty.gif)
