Keypad question
Old Dec 12, 2003 | 11:53 AM
battleminnow's Avatar
Keypad question
So i can't search because of the server stuff going on. Can someone remind me how to reprogram the keypad code? It has been years since I have done it. I know where the number is under the dash, but what order do you enter start and code and etc.? Also, isn't there a finalization process? BTW, it's a 91 GXE.
Thanks,
Pete
Old Dec 12, 2003 | 12:09 PM
DMad8724's Avatar
I have the same car, good choice, anyway, take that code you have. I believe it starts like S324873 or something like that. Type that in, then it should ring for about 10 seconds, WITHIN THAT 10 SECONDS type in the passcode you want, no need to hit the start button, then try and make sure it worked!
Old Dec 12, 2003 | 12:36 PM
harrymay's Avatar
i have the keypad on my gxe, what the heck does it do apartfrom unlock the doors, i know my friends exploder rolls down the windows and opens the trunk.
Oh and where should the override code be, i have no manual, and a tore apart my kickpanels and i couldnt find it
Old Dec 12, 2003 | 01:34 PM
DMad8724's Avatar
It can roll your windows down by pressing and holding 5WDW(5) after entering your code, it can also open your trunk by pressing 1TRK(1). The 9LCK(9) button locks your doors. Under the glove box compartment, lay upside down and it should be to your left. It's a sticker with a code on it on this goldish box (for me anyway). Good luck!
Old Dec 12, 2003 | 06:21 PM
drakken789's Avatar
Would my 89 se have the keypad?, and does anyone have a picture of what this looks like? the keypad i mean
Old Dec 12, 2003 | 06:41 PM
icemanhg3's Avatar
The place where you pull the handle to open your door is where the keypad will be. If when reach down to open your door, you see little numbers on the handle, then you have the keypad. If you don't see numbers, don't worry about it. If your car is an SE, you won't have it. If you have a remote (factory), you won't have it.
Old Dec 12, 2003 | 10:23 PM
harrymay's Avatar
i have a remote, a factory one, it doesnt work coz i suspect it needs a new battery but i havent bought it yet. is it supposed to have the remote if its a gxe?
Old Dec 13, 2003 | 08:42 AM
GRNMAXDMON's Avatar
i was told that the GXE model didn't come with a factory remote at all. my GXE has the keypad and it should be a 7 digit code on that goldish box. if ur car is equipped with sunroof it will also open the sunroof at the same time with the two front windows. now all SE models don't come equipped with the keypad. once u put in the mastercode in within the 10 seconds that it beeps input the code that u can remember and keep the mastercode like in ur wallet or somewhere u know its safe.
89 - 94 GXE = equipped with keypad
89 - 94 SE = not equipped with keypad
Old Dec 13, 2003 | 11:28 AM
harrymay's Avatar
damm, thats quite a max.
whenever i bought the car the remote was sittin in the console and wasnt working. i guess that is why it doestn work.
when i override it, should i do it on the drivers side, or the passenger side?
Old Dec 13, 2003 | 11:40 AM
harrymay's Avatar
ok so i went looking for it, and i couldnt find it, i dont know if im not looking in the right place or whether it has been taken off by the dealer
if anyone has a pic, it could help me a lot
Old Dec 13, 2003 | 03:13 PM
GRNMAXDMON's Avatar
its under the dash on the passenger side. just get a flash light and a paper and pen and look for a goldish box with a white sticker and it has 3 lines of digits. look for the 7 digit code and thats it. and when u override it u can do it either on the driver side or passenger side. good luck.
rick
Old Dec 13, 2003 | 03:46 PM
rrrfoma's Avatar
... while under the dash, look in the direction of a RH door hinge (box is under the RH vent)
(can it be explained in any simplier way? )
Old Dec 13, 2003 | 04:11 PM
harrymay's Avatar
thank you very very much, whenever i was underthere i didnt even see a gold box, im fixin on goin back out there now
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
