How to remove cigarette lighter from dash trim panel?
Old Dec 12, 2003 | 02:40 PM
fmalgapo's Avatar
I'm swapping out dash trim pieces...I got the switches out but can't for the life of me remove this damned cigarette lighter...
Tried the search, but gives me a "You do not have permission to access this page. This could be due to one of several reasons:..."
Tried the FAQs but no mention of the removal of the cigarette lighter..
please help!
Old Dec 12, 2003 | 03:35 PM
reygarcia's Avatar
Loved by MrGone longtime
Disconnect the connectors from behind. Mine were a PITA the get off at first.
Old Dec 12, 2003 | 03:52 PM
94M@X's Avatar
Yup, should be able to just pull the connectors out.
Old Dec 12, 2003 | 03:53 PM
fmalgapo's Avatar
No, i got that much...im talking removing the whole cigarette lighter OUT OF the trim panel....whole unit
Old Dec 12, 2003 | 03:56 PM
DMad8724's Avatar
im not sure you can without breaking some glued seal
Old Dec 12, 2003 | 04:19 PM
reygarcia's Avatar
Just wiggle the cig lighter. Mine pops out easy.
Old Dec 13, 2003 | 07:43 AM
fmalgapo's Avatar
This is what is looks like....I'm trying to swap it over to a new trim panel...Should that white piece come out with the connector come out on top of it? What did you guys do??
I am able to pop it forward towards the front of the trim panel somewhat, but the harness piece catches and I can't remove it...I can also pop it backward, but I think the lip of the lighter holds onto the front of the trim piece...My gf needs the new panel, yet also needs the lighter for her phone charger.
Old Dec 13, 2003 | 07:46 AM
2k3TitaniumSe's Avatar
give it a yank and pull it out.
Old Dec 13, 2003 | 07:48 AM
fmalgapo's Avatar
In which direction...?? I don't wanna break this thing.
Old Dec 13, 2003 | 10:41 AM
rrrfoma's Avatar
never done this myself. but if you are swapping out dash trim pieces only and don't want to break anythng - cut the trim and take it out ...
Old Dec 13, 2003 | 10:44 AM
maxinmaxima's Avatar
I just hit mine out from the back. It has to come out towards the front of the trim piece, towards you if it was still mounted in the car.
super32's Avatar
Donating member? what the?!
fmalgapo-
love your couch covers, they go well with the console.
Just kidding....
Old Dec 14, 2003 | 07:57 AM
fmalgapo's Avatar
Well I got it out....Simply yanking it out of the panel DOESNT WORK!! Like i said earlier because of the white connector in the back, and the light ring out front....
HERES THE SOLUTION:
Inside the metal housing of the lighter, are small square plastic tabs...take something small, and push these plastic tabs down, while pushing the housing out from the back towards you...this will seperate the metal cylinder housing, from the white plastic connector piece and resulting ring. After this...the plastic piece in back will seperate from the trim piece...
Now if only the search function worked...people can see this solution.
The Frye
Feb 3, 2019 08:34 AM
Robert Schneeweis
Jan 11, 2017 06:47 PM
Kingofmaximas24
Nov 12, 2015 04:40 PM
tgreen
Oct 18, 2015 06:18 PM
brichi
Sep 14, 2015 05:23 PM
