removing fuses from box under hood....and removing fuel filter.
Old Dec 16, 2003 | 08:38 PM
azmalu's Avatar
hey yall these are both things that i need to check and replace. ive taken teh screws off the clamp and its not coming off. can i just cut the hose? i dont see why not but thought i would double check. when i put the new on onn do i need to torch the hose so that it seals properly? and for the fuses under hood how do i pull them out...i had a recent thread about how i was messing with remote wires that went to toggle switch for sub amp and now ive shorted something out because clock display is gone door lights are gone and air bad light is on the dash all the time
Old Dec 16, 2003 | 08:52 PM
subs1000w's Avatar
definitly dont torch anything under your hood
you can cut the hoses off but there may not be enogh hose left to put the new fuel filter on so you would have to replace them
try turning the hoses on the fuel filter with a pliers then try twisting them off
the fuses you are looking for are proboly in the car under the driver side dash there labed on the cover
Old Dec 16, 2003 | 10:22 PM
ghostmax's Avatar
have you depressurized your fuel system by taking out the fuel pump fuse (in the kick panel) and trying to start the car (about 3 times)?
do this first, then remove the fuel filter and get ready to catch some gas from the lines.
you blew a fuse in the kick panel too. it's the taillamp fuse or room or stop tail. just pull them and check them.
Old Dec 17, 2003 | 02:20 AM
nubiannupe's Avatar
OG Maxima.org Member
Dawg... if you torch anything under your hood where there may be lingering fumes from your fuel....
Old Dec 17, 2003 | 03:36 PM
87MustangGT's Avatar
Just step back and think about what you're saying for a minute...
Should I...TORCH...the FUEL...lines...
Old Dec 17, 2003 | 08:51 PM
KLoWnPR109's Avatar
Torch.....fuel.....boom
Old Dec 17, 2003 | 09:59 PM
MrGone's Avatar
Its going to explode no matter what, I really dont see what the big deal is
Old Dec 17, 2003 | 10:53 PM
azmalu's Avatar
okay yall sorry very ignorant comment. what i was thinking is that there was some kind of additional sealing that was being done because it was such a ***** to get the fuel filter off. its done and im still in one piece.
Old Dec 18, 2003 | 03:28 AM
nubiannupe's Avatar
Ya know we gotz ta look out for our Maxima bretheren...
But to be honest, when I changed my filter, I had the same problem. I just put a bunch of shop towels around the area to protect against spillage, grabbed the filter, and pulled for all it was worth.
Old Dec 19, 2003 | 07:21 PM
azmalu's Avatar
hey yall my fuse problem is gone now once i had the new headunit installed but just in case how do i pull out those fuses under the hood ?
conansriver
Sep 11, 2015 10:26 AM
Colossus
Sep 9, 2015 05:46 AM
jwright36
Sep 8, 2015 11:45 AM
sdotcarter
Sep 2, 2015 09:53 PM
