Window regulator problem??
Old Dec 19, 2003 | 09:54 PM
cmuehlenb's Avatar
My driver's window will go down but not up sometimes. I can hear the relay clicking when I hit the switch, but there is no movement from the window. This is the regulator, right??
Thanks!!
Old Dec 20, 2003 | 12:00 AM
Golden Ice's Avatar
should be yes...front regulators are cake to change with instructions from Craig Brace's site..
www.geocities.com/craigbrace I think..
Internetautomar sells them pretty cheap ($45), and they dont require any special tools..just a #3 phillips screwdriver (magnetic is a must pretty much), a 10 mm socket or adjustable wrench, the destructions, and a slotted screwdriver..if you have a door panel removal tool, great, use it and you wont damage as many of your plastic clips..
Old Dec 20, 2003 | 02:35 AM
rymo926's Avatar
could that also be a bad motor or just regulator, cuz mine does the same,I thoought a bad regulator causes the glass to shake but not moving or moving slow, would be the motor, I guess some insight on this can help me out too.
Old Dec 20, 2003 | 07:22 AM
Cliff Clavin's Avatar
Way out West
If your regulator gets fouled up inside, it can still go up, but it makes the motor work hard to get the window to go up. Mine was going up super slow before the regulator finally fried. One day I went around a corner and the window just dropped into the door. It looks like the top pulley just broke apart, but there was damage to other pulleys, too and I think those other pulleys were what caused the window to go up so slowly.
My regulator came with a new motor, but I gave a guy with a Nissan Axxess (?) my old motor and it works just fine in his car.
Old Dec 20, 2003 | 11:21 AM
Golden Ice's Avatar
when the regulator on my back left door went bad, it went down and stayed down..fortunately, the back windows don't go down all the way, so I taped it up for about 7 months before fixing it..then realized that the back windows not going down all the way is a real handicap when you change the regulators on them..you can't get to the screws that attatch the regulator to the window nearly as well as you can on the front doors..
Old Dec 20, 2003 | 02:20 PM
DMad8724's Avatar
say someday i change my regulators/motors in the back, is it possible to make the window go down all the way?
Old Dec 20, 2003 | 02:41 PM
shoult's Avatar
Not unless you change to itty-bitty rear tires and cut a slot for the glass in the rear wheel wells.
Look at the relationship of the rear wheel arch, the door and the glass.
Old Dec 20, 2003 | 03:42 PM
male's Avatar
Does your window wobble in the track? Mine did the same thing, needed help coming up, so I took off the door panel and brushed the window track with silicone lube from the bottom to the point that meets the rubber upper portion. No problems ever since...
Old Dec 20, 2003 | 06:49 PM
internetautomar's Avatar
mod or sell?
Easiest way to checkmotor VS reg is to listen to the door while pushing the window switch and listen for the motor
While not 100% foolproof it is a good indicator
Old Dec 21, 2003 | 12:19 AM
rymo926's Avatar
The motor goes eeeuuummm, with little action or it goes click and no action, but acouple of clicks and eeeeuuuummmm.
wow that's just sound stupid^,
rymo.rymo
Old Dec 21, 2003 | 07:28 AM
mod or sell?
Bad regs
no surprise but just wanted to be sure
Old Dec 26, 2003 | 08:08 PM
cmuehlenb's Avatar
Thanks very much for the infomation. This was an informative thread.
I ordered a regulator on Ebay for $45. I think it comes with a motor. If it doesn't need a regulator now, it will someday, so I will install it and see how it goes.
Old Dec 28, 2003 | 03:32 AM
Golden Ice's Avatar
its up to you where you want to get your parts, but I'd encourage people to support .org members sales..internetautomar sells the regulator alone for $45, and you use your current motor..after putting new regulators on, my windows were sluggish to go up and down, while when my front left one went out it zipped up and down..well, the front left one went out and 2 days later it had a new one in it (had it done at a body shop since it was the middle of winter and at the time, I had no clue what I was doing..), while the back left one and front right one had been bad for awhile..in fact, the front right one was bad for over 2 years before I changed it, my uncle and I just reversed part of the cable to lock the window up..well, I had thought the motors were weak and about to go out, but they work pretty well now..I guess sitting for awhile is kinda hard on them..
Old Dec 28, 2003 | 06:06 AM
mod or sell?
Some people think everything on ebay is cheaper. but they tend to ignore shipping costs. and how were the parts bought?
new from a store with a guarantee
or as part of a "distressed" mercahndise sale?
with parts of questionable quality and history.
yes today is my preachy day
YOU HAVE BEEN WARNED!
Old Dec 28, 2003 | 01:35 PM
cbrflyer919's Avatar
Craig's website doesnt wor!! Does anybody else know where to get good instructions on how to chage the regulators???
Old Dec 28, 2003 | 05:29 PM
«§»Craig B«§»'s Avatar
my site works fine, sometimes geocities will temporarily shut it down if it uses too much bandwidth, but it'll tell you that and you can try again in a few hours. I just checked it now and it's fine.
if for some reason, it's still not working, there is a copy of it (just the regulator article) on www.bignissans.org.uk in the J30 section under common problems
JoshG
51
Sep 21, 2015 10:41 PM
thenewguyy
Sep 12, 2015 11:12 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
