sputtering engine
Old Dec 24, 2003 | 04:23 PM
animatorelt's Avatar
sputtering engine
anyone experience sputtering in your max? feels like a misfiring spark plug, but i can't be certain. what should i do? and how can i check the ECU code? how does one do that?
Old Dec 24, 2003 | 07:16 PM
internetautomar's Avatar
mod or sell?
First thing to do is update your profile with what year and model your max is.
Then start disconnecting the cylinders one at a time until you find the cylinder/s that doesn't affect the cars running and that will be the begining of finding the problem
Old Dec 29, 2003 | 11:51 AM
i have a 93 SE. is it safe if two cylinders are off, while the engine is turned on? also, is it ok to disconnect them while the engine is running, or must i re-ignite the engine after each try?
Old Dec 29, 2003 | 01:50 PM
mod or sell?
Ok you've got it "easy"
The connectors on the coils are easy to do and undo.
You do it while the car is running.
But only disconnect 1 at a time.
Leave the car running the entire time.
That's how I found out I bought a 3 cyl maxima. thenit turned into a 5 now its finally a 6
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
