A/F Gauge where and hot to hook up?!
Old Dec 30, 2003 | 04:53 PM
MadMax92's Avatar
Alright guys I just bought a A/f Gauge for my 92 maxima se and it says to run the signal wire to the signal wire from my o2 sensor. For some reason that doest seem to work can you tell me which wires you guys are hooking it up to? Thank you very much.
Steve
Old Dec 30, 2003 | 05:13 PM
MrGone's Avatar
ummmm
gimme a minute
Old Dec 30, 2003 | 05:23 PM
MrGone's Avatar
Old Dec 30, 2003 | 05:32 PM
MadMax92's Avatar
Is this the schematic of the wires on the clip to the ecu?
Old Dec 30, 2003 | 05:33 PM
mtcookson's Avatar
yeah, that's right on the ecu.
Maxima-4DSC's Avatar
YoU CaNt SeE mE
looks like it to me.
Old Dec 30, 2003 | 05:38 PM
MadMax92's Avatar
Thanks Guys.
Old Dec 30, 2003 | 05:43 PM
MrGone's Avatar
yep and "w" means white.
IIRC its the top row and its on the side of the bolt closer to the firewall, but please double check before you tap.
Old Dec 30, 2003 | 05:48 PM
MadMax92's Avatar
Have you guys installed one yet? how does it act? and does is take long to start reading?
Old Dec 30, 2003 | 05:49 PM
MrGone's Avatar
I posted a thread with a video awhile ago, it starts reading as soon as its hooked up.
how does it act? keeps the passangers entertained
Old Dec 30, 2003 | 06:39 PM
nubiannupe's Avatar
OG Maxima.org Member
And here I was gonna run MY wire all the way out to the O2 sensor itself...
Old Dec 30, 2003 | 07:32 PM
GRNMAXDMON's Avatar
i still have to hook mine up. but don't know if its the same wire for the GXE model??? can u guys help me out on that??? i have the autometer indiglo a/f gauge btw.
thanks,
rick
Old Dec 30, 2003 | 09:29 PM
MrGone's Avatar
http://forums.maxima.org/showthread.php?t=270708
video thread
Old Dec 30, 2003 | 09:32 PM
MrGone's Avatar
i'll try to get a picture of mine. I've got a few wires tapped because of other mods (VTC's, Variable Intake, etc)
Old Dec 30, 2003 | 11:20 PM
shoult's Avatar
They should start working immediately. Although they will act different from cold start to a fully warmed O2 sensor. That only takes a minute or so.
It should osillate between lean and rich at idle and when cruising. This is closed loop operation. Your watching the ECU trying to keep the engine in stoich combustion. If you have one of those silly round 10 led meters then you'll get VERY little useful info during closed loop operation.
When you mash your foot to the floor you enter open loop. This is what the meter is really designed to monitor. Hopefully it will not go red (lean) at all, but stay in the middle rising to the high middle. If it goes too rich your losing power. Too lean and BOOM!
But you can't really use these things to tune your engine. The problem is that the everyday O2 sensor isn't very accurate or fast. You really need to get a calibrated lambda O2 sensor and they are VERY pricey. But you really only need that if your looking for that every nth degree of advantage. But then youd also probably be running EGT meters too.
Overall, 10 digit Air/Fuel meters are a very imprecise view of a very imprecise measuring device. They are useful for trending analysis of your engine. If it always lights one way and then one day starts doing something different you know something is wrong. Or if it gradually starts displaying differently something is working different.
As far as my reference to 10 digit devices, I have a Halmeter which uses 30 leds and is MUCH easier to see what is going on. It wasn't much more then the 10 digit units though it is bigger.
Old Dec 31, 2003 | 08:08 AM
GRNMAXDMON's Avatar
ok but i still want to know if its the same wire for the GXE model??? cuz the schematic that was posted by MrGone is probably for an SE and i have a GXE and all i want to know if its the same wire or if its different???
Old Dec 31, 2003 | 08:11 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
pretty sure its the same wire for the GXE...I had one in mine and I specifically remember tapping the white wire
Old Dec 31, 2003 | 08:14 AM
GRNMAXDMON's Avatar
thanks da-max
Old Dec 31, 2003 | 10:23 AM
MrGone's Avatar
i double check for you, GRNMAXDMON
Old Dec 31, 2003 | 10:30 AM
MrGone's Avatar
GRNMAXDMON
according to the FSM, you are going to need to tap wire #29
Old Dec 31, 2003 | 10:52 AM
DA-MAX's Avatar
GRNMAXDMON
damn back in the day I wonder if mine was even on the right wire then...I was probably getting AF readings from the ignition and what not
Old Dec 31, 2003 | 11:01 AM
MrGone's Avatar
if it helps any #29 is right below #39 and is white aswell
Besides I betcha you got the right wire Addae... on the VG #39 is a green/red wire that goes to the EGR Temp Probe
Old Dec 31, 2003 | 01:55 PM
GRNMAXDMON's Avatar
thanks MrGone now i can finally install this damn thing.
Old Jan 17, 2004 | 02:40 PM
punabrew's Avatar
I have a 90 VG SE need to hook up gauge, don't wan't to tap ECU, down at the o2 sensor theres a white, green, black wire which do I need to tap.
Old Jan 17, 2004 | 02:44 PM
MrGone's Avatar
white.
10chars
Old Jan 17, 2004 | 02:57 PM
punabrew's Avatar
is that on the sensor side of the connector or the motor?
I have a bosch sensor, they have diffent color wires.
Old Jan 17, 2004 | 03:08 PM
MrGone's Avatar
wiring harness side (ie. oem). Just trace the wire.
It really is easier and better to do it from inside the car though, it's protected from the elements, and since it uses small differences in voltage to get a reading, you really dont want corrosion to start forming on the wires.
Old Jan 17, 2004 | 05:07 PM
punabrew's Avatar
I tapped into # 39 and still no read out, just black no leds lite up, without the signal wire hooked the last green led is lite up. this sucks.
Old Jan 17, 2004 | 05:26 PM
MrGone's Avatar
Puna, your a VG, you need to tap wire 29.
Old Jan 17, 2004 | 05:58 PM
punabrew's Avatar
Attention ALL VG OWNERS TAP INTO #29 WHITE, its the only way to do it, you can't tap in at the sensor it simply won't work.Thankx MRGONE for all the help.
Old Jan 19, 2004 | 08:49 PM
pest2001's Avatar
does any one have pics of where to tap it becase i dont know which on i taped it to so if someone can please post pics it will be really great
thanx
william
Old Jan 19, 2004 | 09:56 PM
punabrew's Avatar
Are you a VG
Old Jan 20, 2004 | 06:13 AM
MrGone's Avatar
take off the drivers side ecu kick panel and tape the wires there
Old Jan 20, 2004 | 07:37 AM
pest2001's Avatar
yea im a vg
Old Jan 21, 2004 | 03:54 PM
pest2001's Avatar
well i wired mine up wrong i tapped into the TPS signal wire and how do we read this schematic what side is the wires coming out of
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
