Stuttering under load
Old Dec 30, 2003 | 05:21 PM
SnickterP's Avatar
Ok, i cant seem to figure out what is wrong with my car....i thought it was plugs or wires but i changed them all and it still has this problem. its lacking power and stutters under load, and even at idle its very rough. feels like a misfire or something. it was intermittant before, sometimes going away. but now after changing the plugs and wires its constant. any clue as to what it could be?
Old Dec 30, 2003 | 05:31 PM
mtcookson's Avatar
hmm... kind of sound like a vacuum leak. my car was doing the same thing a week a go or so. i just check the vacuum lines that i though were bad and fixed them. first place to wheck would be the egr valve. that seems to be causing a bit of trouble with a lot of people lately.
Old Dec 30, 2003 | 09:48 PM
SnickterP's Avatar
Thanks for the info...i'll have to check on that in the mornin
Old Dec 31, 2003 | 07:59 AM
EWillden's Avatar
i have the same problem eith my max. Where is the egr valve located?
Old Dec 31, 2003 | 12:59 PM
SnickterP's Avatar
Well it doesnt really seem to be vaccum related that i can tell. The EGR is fine...i double checked the plugs and made sure the gapping was correct, i even messed with the o2 sensor making sure it was clean after reading that it was the cause of another persons problem. i cant seem to figure it out what is wrong.
Old Dec 31, 2003 | 01:22 PM
Bill Brasky's Avatar
Seperated at Birth?
check your air filter for obstuctions. when this happened to me, i had a nice chunnk of duct tape covering my maf.
Old Jan 2, 2004 | 11:42 PM
SnickterP's Avatar
I still cant seem to figure out what it was...but strangely enough the problem has seemed to have fixed itself again. weird
Old Jan 2, 2004 | 11:54 PM
92GHETTOCRUISER's Avatar
This is a common problem with the vg, mine does it every 3 out of 10 times i start the car. I have found that if i turn it off count to 5 and start it again it runs fine . but with all the people i see on here ,just about every week. We need to figure this out already , i know someone here has fixed this completely. also i have replaced about every component related to this problem.
Old Jan 3, 2004 | 03:03 PM
Paul89SE's Avatar
I have the same problem and i thinkit's ECU related. Like you said if I shut it off and let it sit for a second it runs fine. BUt, if i try to drive without doing this it wants to stall when i put it into gear.
QUOTE=92GHETTOCRUISER]This is a common problem with the vg, mine does it every 3 out of 10 times i start the car. I have found that if i turn it off count to 5 and start it again it runs fine . but with all the people i see on here ,just about every week. We need to figure this out already , i know someone here has fixed this completely. also i have replaced about every component related to this problem.[/QUOTE]
jmlee44
Oct 2, 2022 02:13 PM
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
fastcarny
Oct 6, 2015 10:42 AM
97_GXE
20
Sep 17, 2015 08:12 PM
