My Speedo Dont Work!!!!
Old Dec 31, 2003 | 12:46 PM
maxman92's Avatar
Ok i have this car a few weeks and I knowticed once before the speedometer got stuck and then would jump alil when I hit a bump. I thought it was doing it because it was cold. It didnt happen for 3 weeks or so. Then yesturday on the way to work it started again and now its gone completely. I took the dash apart and made sure all the connections were good and still no luck. I did fix my clock though.
Tomorrow i will get under the car and check the speedo cable. Has anyone else experienced this before? Any help would be great!
By the way its a 92 SE with only 75k on it.
Old Dec 31, 2003 | 12:55 PM
MrGone's Avatar
we just had to replace the gauges in antonthegreys car. maybe try resoldering all the little points on the speedo?
Old Dec 31, 2003 | 12:58 PM
maxman92's Avatar
the speedo comes out seperate right? That fixed my clock maybe it will fix that too.
Any other ideas guys???
Old Dec 31, 2003 | 12:59 PM
MrGone's Avatar
yep
unbolt the 4 bolts on the back of the speedo and it should just come out, IIRC.
Old Dec 31, 2003 | 01:19 PM
maxman92's Avatar
I forgot that when i washed the car a few nights ago i sprayed water under the car and maybe i knocked somehting out or broke something.
Is this possible?
Old Dec 31, 2003 | 01:23 PM
internetautomar's Avatar
mod or sell?
Very possible
Old Dec 31, 2003 | 01:32 PM
maxman92's Avatar
Ok one question. The speedo cable goes from the tranny to where? I pulled the dash off and the cable dont go to the cluster so where does it go? Do i even have a speedo cable?
Old Dec 31, 2003 | 01:50 PM
Bill Brasky's Avatar
Seperated at Birth?
no speedo cable. it's all electronic.
Old Dec 31, 2003 | 03:24 PM
KRMaxima21's Avatar
On my VG there was the harness that the speed sensor wire runs to and another wire that looks like it runs down to the tranny. It has a clamp that sits like right next to the oil filter and that wire got burned by the oil filter. I tried seeing if maybe electric tape could fix it but there was no use so I gotta find a way to do it when the car is not hot and see if the wire is removable so I can solder some new wire there and re-install it. Check to see if you have any fried wires near the oil filter. That might be a reason
Old Dec 31, 2003 | 08:49 PM
Evil_Twin's Avatar
So what would you guys do if the backlight on the speedometer doesnt turn on anymore after splicing the cigg lighter?...
o_O Confused
Old Jan 1, 2004 | 10:32 AM
2k3TitaniumSe's Avatar
This problem sounds familiar.
Old Jan 2, 2004 | 02:54 PM
maxman92's Avatar
I found the problem. The speed sensor wire pigtail came loose. I tried to and clean the speedo and resolder it but by doing so i think I broke the speedo. Because now the odometer works but the speedo dont..
Old Jan 2, 2004 | 03:43 PM
Evil_Twin's Avatar
hmmm... where'd you do that?... I need to find somewhere I can plug something in, because I think there's a loose wire somewhere.
Old Jan 2, 2004 | 03:58 PM
maxman92's Avatar
The sensor is located in the tranny close to the firewall. Below the fuel filter. It has a brown pigtail. This in on a 5spd not sure about a auto.
Old Jan 4, 2004 | 10:22 AM
Maxdude's Avatar
I had the same problem with my 91 SE where my odo nor the sepeedo was working and I had to change the speedo sensor right below the oil filter. It's an easy process and I believe this should fix your problem. I paid $50 for it at the junkyard.
Good luck
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
