stock suspension/ safety question, pelase help!!
Old Jan 2, 2004 | 07:34 PM
rambo91145's Avatar
hello all,
i am leaving for vaction tommorow morning and will be going 2000 miles round trip. i have a 91 nissan max SE. now for my question. the right front fender is resting about 2 inches from the top of the tire, looks like it would look on a lowered car. the rest are normal. is this a blown/bad shock? or maybe a broken spring?? is it safe to drive it at least half the trip? i dont really have time to fix it until i get there but i will postpone my trip if i have to. thanks for all your advise!
zack
Old Jan 3, 2004 | 01:54 PM
super32's Avatar
Donating member? what the?!
You can easily check if it is a broken spring, just look under the well.
I'm anticipating a bad shock. But to check, push on that side and see how it reacts. If there are NOT performance shocks, but are stock/regular shocks it should give good bouncing; soft, strong, and noiseless.
Just compare that side with the other side. If there is huge difference, then you need to replace that one bad strut. ~$80-$100 and about 1 hour of mechanic labor.
I suggest changing as early as possible. If that shock completly gives out (i.e. lose all of it's ability to suspend that side) your car will start depending on the spring. I don't think the spring can completely suspend the car so evertime you go over roadway that makes your car bounce, that side will start bottoming out, which can start damage to your strut tower.
Strut tower damage won't let you decide when to postpone your trip.
Drive safe.
Originally Posted by rambo91145
hello all,
zack
Old Jan 3, 2004 | 06:33 PM
internetautomar's Avatar
mod or sell?
Drive safe.
NEVER replace struts singlely (sp?).
Your spring can very easily support the weight of the car, that is it's purpose!
The strut is there to limit the bouncing so that your tires remain in contact with the road.
Worn struts will cause handling and braking problems well before you "feel" that they are worn.
Struts are a SAFETY item not a comfort item contrary to popular belief.
Old Jan 4, 2004 | 02:39 AM
Bman's Avatar
If you have one corner of your car sitting lower than the others, I would say it is either a sagging or broken spring, or some other worn/broken related part, maybe like a strut mount (?). Hopefully it's not some structural problem.
I'm pretty sure that no matter how blown your strut is, it's not going to change the ride height.
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
pktaske
May 6, 2016 07:49 AM
BkGreen97
Apr 2, 2016 05:47 AM
pktaske
Sep 4, 2015 08:40 AM
