Stalling 93 GXE...Nissan mechanics no help. Any more ideas?
Old Mar 2, 2001 | 08:19 PM
erinscot
On Feb 22 da_whites wrote:
I have a 93 GXE automatic with no mods(just the family car). I love this car and have done all the work on it. It has 150,000 miles and all of a sudden began to stall all the time. Not sputter like bad gas, fuel pump problems or fuel filter stuff but just quit,as if you pulled a plug. It does it sporatically and will start right back up. All the auxiliary lights, blower and electrical parts work but the engine quits. I tried the O2 sensor, plugs, plug wires but nothing. I broke down and took it to the nissan dealer but they could not find anything. The diagnostic did not show anything. I have had it back 4 times and through it all replaced the ignition coil, distributor, eng cont relay, had the injectors cleaned and the diagnostic test. IT STILL IS STALLING. The gas mileage is down but it runs like a champ. There is no difference in driving performance. It will cut out at any rpm, accelerating or decelerating. The nissan dealer is beginning to fish for ideas. I am looking for a place to start looking before they have me replace the engine piece by piece.
Well, I also have a 93 GXE, with what seems to be the exact same problem. We thought it was related to humidity, but it also occurs on dry days. My mechanic even went so far as to pressure-spray water all over and around the engine, but it would not stall. Mechanics have supposedly ruled out ignition and fuel problems. One post suggested it could be the catalytic converter. As the RPM's do not seem to be limited and the problem is quite sporadic (sometimes several times in a half hour, other times we can drive for 200 miles without a problem), I don't know if the converter is the problem.
Any other ideas?
Scot Mundle
Old Mar 2, 2001 | 09:03 PM
93 SE's Avatar
my old car died on me for no reason like that...it was the main fuse for me...probably the reason they cant find a problem...cuz if its on tight the car will work fine but if its loose and doesnt connect good it will shut down the car ...hope that helps..
Old Mar 3, 2001 | 05:01 PM
brubenstein's Avatar
It might also be that the fuel pick up screen in the gas tank is partially blocked.
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
