Some simple pics of the 13" Cobra bracket and caliper
Old Jan 5, 2004 | 11:19 AM
Jeff92se's Avatar
I'm needing a caw
Polishing is just preliminary stages. Some areas are polished just to show how it might work. Those are the production brackets though. I've since ground off the "sumitomo" as it was too much of a pain to polish around. I've ground off some other little items also.
Old Jan 5, 2004 | 11:29 AM
MrGone's Avatar
Awesome work Jeff!!!
I can't wait for a ride
Old Jan 5, 2004 | 11:36 AM
davebond007's Avatar
Hm, nice and shiny.
Btw, I still want a set of those brackets.
Old Jan 5, 2004 | 01:07 PM
D-sta's Avatar
Lookin good Jeffy. Now get the other side done and show pics with the mustang wheel on.
Old Jan 5, 2004 | 01:28 PM
mtcookson's Avatar
i must have missed something somewhere. what are these calipers off of and what are they going on?
Old Jan 5, 2004 | 01:51 PM
jaemax's Avatar
great job... I have those calipers the only pain is I want larger rotors but dont have the bracket... please inform me of where to get... or maybe u and I can work something out.. thanx
jaemax
Old Jan 5, 2004 | 02:23 PM
crsmax's Avatar
Looks good Jeff... glad to see such strides in the 3rd gen community...
Old Jan 5, 2004 | 05:20 PM
Walka's Avatar
looks sooo nice! mucho caliper envy here. im guessing this is dremel work? how many hours did you put into each caliper? polishing is not easy stuff. i polished 2 of my wheels so far. i got lazy and i still havent done the other two.
walka
Old Jan 5, 2004 | 06:01 PM
Jeff92se's Avatar
I'm needing a caw
The calipers look much shinier now. Most of that caliper in the picture is just sanded
Most if it is fairly easy. I found that using a 120grit flapwheel on a drill works to get 85% of the caliper sanded smooth. But it's the little fin areas and the "wave" areas on either side of the caliper that takes mucho time. Here is the process I have done.
1) Big aluminum grinding wheel to grind off the sumitomo and the little casting "circles" on either end of the caliper. That takes maybe 20min. Just avoid putting big gouges in the aluminum.
2) Sand those areas with 80 grit sandpaper. Again not hard.
3) Use the 120grit flapwheel on the drill and smooth as much as the caliper as you can.
4) I hand sanded the 120 scratches down with 220 grit paper.
5) Then I used 3m rubbing compound and some dremel polishing wheels to take the 220 off. This makes is pretty shiney. Most sites will tell you to sand with 600, 800,1200 etc.. funk that man.
6) Then do a final polishing with the Simichrome or that Nambe stuff to get it super shiney.
The hard part is the little fin areas. What a pain.
Total time for one caliper? Probably a good 4-6 hours. I just do a little at a time
walka
Old Jan 5, 2004 | 10:50 PM
Jeff92se's Avatar
I'm needing a caw
For Donald. I bought the brake lines here:
http://www.anplumbing.com/
fronts are 22" long. Stock is 20" long. I think the stock 20" would be fine. p/n is 63071022. (22")
rears are of course stock length. p/n 63071520
I have NOT trial fitted the lines other than checking to see if the lines thread into the caliper. Which they of course do.
Old Jan 6, 2004 | 10:11 AM
nismo_s13's Avatar
OOooOOOoohhhhh... i want a set...
Old Jan 7, 2004 | 08:57 PM
Maxima90SE's Avatar
looks good...cant wait to see it on the car.
Old Jan 12, 2004 | 02:09 PM
Jeff92se's Avatar
I'm needing a caw
Install was a success! Brackets and calipers line up perfectly. Also the SS lines work and fit perfect. Although, I'd go with the stock 20" front line instead. No need to order the 22" front line.
No rubbing anywhere and fits under my 17 x 8 rims perfectly.
Davebond took pics and they should be up in a day or so.
I'm still bedding in the brake pads and I'm using some cheapie Napa units. But it gets better and better the more I drive it.
The 13" rotors look HUGE under these rims.
Old Jan 12, 2004 | 02:56 PM
90SEBlack's Avatar
Jeff what are the calipers off of ??
Old Jan 12, 2004 | 03:01 PM
Jeff92se's Avatar
I'm needing a caw
A Nissan! heh. 300zx All aluminum. 30mm version.
I think he got them off a Z32 TT a while back... not sure. I think you could get them (the aluminum 30mm calipers) on Skylines too.
Old Jan 12, 2004 | 03:05 PM
90SEBlack's Avatar
So other than the bracket that u made did u have to make any other mods to the braking system. Im thinkin of selling my SSBC calipers those would look better and the say Nissan on them, u think a yard would have some?
Old Jan 12, 2004 | 03:06 PM
More pics here: http://gallery.launch2k.com/jeff92se
Old Jan 12, 2004 | 03:07 PM
Jeff92se's Avatar
I'm needing a caw
Thanks Dave!
90SEBlack's Avatar
SICK!!!!!! Those are sweet!!!!!!!!!!!!!! U refill ur CV jonts to as a routine thing or were they actin funny? Once again they look very nice. Must stop the car on a dime, Are they 300ZX rotors then also. Are master cylinder has no problem pushing them they look huge!!
Old Jan 12, 2004 | 03:28 PM
Jeff92se's Avatar
I'm needing a caw
Ah no comment on the CV joint!
13" Ford Cobra rotors. ie.. 98' Cobra
30mm Nissan 300zx aluminum 4 piston calipers
Custom brake bracket (arranged by me )
Custom front SS lines, standard ss brake line in back
Old Jan 12, 2004 | 03:36 PM
MrGone's Avatar
those rotors look familiar
Jeff was also saying he noticed he has to push farther on the pedal (moving more fluid), but it's quite nice
Old Jan 12, 2004 | 05:23 PM
internetautomar's Avatar
mod or sell?
Have you done anything to upgrade the rear?
Old Jan 12, 2004 | 06:06 PM
Julio's Avatar
Are you selling the brackets to others by any chance? I would be willing to buy them for 40 bucks. Did you make them, or did you have a machine shop do it up?
Old Jan 12, 2004 | 11:25 PM
CandiMan's Avatar
Say Candyman 5 times
If you guys are truely interested in Jeff's "exact" set-up, along with all the parts he listed you will need hub centric rings to center the Cobra rotor onto our hubs. I did a GD in the pass for the rings and it turned out pretty good. Due to popular demand I was asked if I could furnish the rings again so I'm currently doing another GD for the rings. If you haven't seen or read this thread ----> http://forums.maxima.org/showthread.php?t=244197 I would suggest reading all 7+ pages, good info and pics. That's right all 7 pages
In short I must say a couple things, both are very important.
1)get the 30mm Z32 calipers and not the 26mm caliper
2)make sure your rims can accomodate this set-up. This one goes without saying, I just trying to make it a point.
Old Jan 13, 2004 | 05:53 AM
nubiannupe's Avatar
OG Maxima.org Member
Yeah... cuz 15" stock ain't cuttin' it!!!
Old Jan 13, 2004 | 10:56 PM
Jeff92se's Avatar
I'm needing a caw
No not yet. Even when the fronts were stock, they didn't do a damned thing. Upgrading the fronts is easier in the fact that you can upgrade the beegezes out of them and it's all good. But the back, you want to make absolutely 100% sure they don't lock before the fronts. Or it's 180 deg time. Not nice.
Old Jan 13, 2004 | 10:57 PM
Jeff92se's Avatar
I'm needing a caw
Funny you ask if I make them but you know the price? I have them mass made for $40+shipping.
Old Jan 14, 2004 | 01:36 AM
Buy a set. Support the cause.
Old Jan 14, 2004 | 06:21 AM
Maximan190's Avatar
isnt that where abs comes in?
btw nice, i like the red "Nissan" rather than the whole caliper being red
Old Jan 14, 2004 | 09:14 AM
Jeff92se's Avatar
I'm needing a caw
I don't have ABS on this car. And you wouldn't really want to rely on a safety system to overcome a design mistake.
Old Jan 14, 2004 | 12:22 PM
CandiMan's Avatar
Ok ladies and gents, I've gotten a couple PM's asking if the hub-rings are still available so I'm going to hi-jack Jeff's thread to post info about the rings. This was taken directly from my other thread on a main discussion forum.
2 orders of rings will be $48 to your door
5 orders of rings will be $43 to your door
10 or more orders will be $33 to your door
All the above prices are base on a PayPal payment, if you desire to mail in a payment (money order, personal check, etc) you can minus $1 from the above price.
My Paypal account info = mikey_rl@yahoo.com
If you want a set (or as many as you want) of rings as of now you can paypal or mail in $33 for each set you want. Drop me a PM or email and I'll give you my mailing address. This is base on a 10 or more orders just in case we reach that amount. You guys surprise me last time so you never know. As the payments are confirmed cash in my account I will let you guys know were we stand in the group deal. If for whatever reason we dont exceed the 10 or more order you guys will PayPal me the difference base on the final count. So keep in mind you might pay as much as $48 a set or as little as $33 a set for the rings. If you understand and this is ok with you my PayPal account is now open.
So far I've got 2 confirmed orders, 3 more confirmed orders and the price goes down to $43 to your door, and so on and so on. I've answered the two PM's that I recently recieved and I'm posting here just incase others may be interested.
MIKE
Old Jan 22, 2004 | 12:51 PM
Jeff92se's Avatar
I'm needing a caw
Performance update. I still haven't 100% romped on these brakes but I've done some 50-75% hard braking. From what I can compare to a stock-ish 3-gen. Ie.. my car/mr. gone's car, the performance is very good. The same pedal pressure hauls down the car much faster. I haven't had the guts to test the fade resistance.
Old Jan 22, 2004 | 01:47 PM
Jon91SE's Avatar
Pusssseeeehhhh
Well what are you waiting for mustang boy!
Old Jan 22, 2004 | 01:57 PM
Jeff92se's Avatar
I'm needing a caw
Your are right. Can you park your car let's say 115ft away while I test these brakes from 60 to 0 mph?
Old Feb 17, 2004 | 08:44 PM
Jeff92se's Avatar
I'm needing a caw
Adaptor brackets from me. $40+shipping. And you need the hub rings from candiman to center the rotors.
You will also need some ss lines. www.anplumbing.com
fronts: 63071020
rears: 63071520
These are for a 3-gen but should be fine for a 4th gen. The fronts are designed to eliminate the small hard line that pokes out of the Z caliper. But if you would rather use the 240 conversion lines, I have an extra front set for sale. $40 shipped.
More info:
Pics here on my car:
http://forums.maxima.org/showthread...highlight=cobra
Old Feb 17, 2004 | 08:47 PM
Jeff92se's Avatar
I'm needing a caw
Pics of the bracket mounted and painted. Also shows the correct way to mount the bracket.
Cobra rotor, ss lines, rotor hub rings and polished calipers.
I have gone though the 2nd batch of brackets and am ready to order the 3rd set. Chime in asap if you want some brackets.
Old May 5, 2004 | 02:23 PM
Jeff92se's Avatar
I'm needing a caw
Update. Got few more front bbk adaptor brackets in. $45-shipped.
Old May 5, 2004 | 02:31 PM
MrGone's Avatar
I spy rexes
.....and they aren't mine.
Old Sep 7, 2004 | 01:08 PM
Ksgarcia's Avatar
how much would it cost to buy the whole brake set, and i mean everything.
