How much should I estimate?
Old Jan 10, 2004 | 08:03 AM
HPSE's Avatar
For timing belt replacement? Car has 97k on it and I don't want to chance much longer.
TIA,
Henri
Old Jan 10, 2004 | 08:21 AM
Paul89SE's Avatar
I paid $300. But you might want to have your water pump changed too though so you're not paying for all that labor if it goes out.
Old Jan 10, 2004 | 10:50 AM
Alpha_'s Avatar
I was able to get my timing belt and waterpump done for $200 both parts and labor. good deal? I think so.
Old Jan 10, 2004 | 11:39 AM
Matt93SE's Avatar
STFU n00b!
using what kind of parts?! $200 is barely enough to cover a new water pump, timing belt, and cam & crank seals.
Old Jan 10, 2004 | 12:09 PM
mtcookson's Avatar
you can find water pumps for 20 bucks and timing belts for 20 as well. the timing belt is a gatorback which i hear are really good. i'm not sure on the cam and crank seals.
Old Jan 10, 2004 | 12:30 PM
99SEL4ME's Avatar
He is asking how much for a timing belt replacement on a 93SE ??? A 93 SE has a timing CHAIN right?? Did anyone catch that? Just curious.
Old Jan 10, 2004 | 12:32 PM
nagal's Avatar
Dreams of a RB26DETT
i got mine from napa i got the timing kit, water pump all of the belts, for 117. and from autozone cam shaft seals, oil pan seal, and crank seal, for 120 or so.
Old Jan 10, 2004 | 12:53 PM
Matt93SE's Avatar
STFU n00b!
He asked about belt replacement, so I gave him an answer. whether he has one or not wasn't his question.
Old Jan 10, 2004 | 01:06 PM
nagal's Avatar
lamo
Old Jan 10, 2004 | 01:54 PM
Cliff Clavin's Avatar
Way out West
I replaced my water pump with the belts for under $200. $100 in labor from my favorite "shade tree" mechanic and a little under $100 for belts and pump, new not reman.
I need to have my front seal re-done, but that mechanic moved, so I need to find another one.
Old Jan 10, 2004 | 02:14 PM
Matt93SE's Avatar
STFU n00b!
front seal is cake... just remove the belts and crank pulley and the seal is right there. remove, reinstall. 30 min job.
Old Jan 10, 2004 | 02:41 PM
99SEL4ME's Avatar
The post says timing belt......
Old Jan 10, 2004 | 02:43 PM
99SEL4ME's Avatar
Whatever I could have sworn the first post says timing belt, no biggie,
Old Jan 10, 2004 | 02:47 PM
Alpha_'s Avatar
Red92MaxSE, not only do you own a car similar to mine in both trim and color, you got my feel in the "shade tree" machanic as well. Those mechanics are the way to go, the guy I had repairing my car is my best bud's dad, so go figure. He did the job in like 3-4 hours. I can't complain, new belt and pump, all for the price of like 1/3 of what was asked for if I went to an "official" mechanic.
Old Jan 10, 2004 | 10:17 PM
HPSE's Avatar
Sorry everyone, I mean't timimg chain.
Thanks for the info, it looks like majority of the cost depends on the mechanic. I will do my research and try to find a good shade tree mechanic and purchase the parts myself and I'll make sure I include the water pump during the process.
Thanks,
Henri
Old Jan 11, 2004 | 07:56 AM
Matt93SE's Avatar
STFU n00b!
Exactly which car do you have, anyway?
If you have a 93SE as your profile says, you don't have a timing belt- it's a chain and doesn't need replaced.
If you've got a GXE or an SE earlier than 92, then you've got a belt and it does need service...
Old Jan 11, 2004 | 08:23 AM
HPSE's Avatar
Matt, Thank You!!!!
DOH!!!!!!!!!
I have a 93 SE 5 spd, so I don't have to worry about the timing chain. So timing chains never have to be replaced, wow? Thats good, matter of fact thats Great! What about the water pump, should that be changed around 100k?
TIA,
Henri
Old Jan 11, 2004 | 08:32 AM
Matt93SE's Avatar
STFU n00b!
it's recommended to change them around 100-120k, but honestly I wouldn't worry about it. it not something that will blow the engine if it fails, other than leave you parked for a day or so until it's fixed. I'd just keep driving. if you start to see antifreeze drips from it, then check it out and replace when it goes.
(My car has over 200k miles on it and I believe it's still on the OE water pump!)
Old Jan 12, 2004 | 10:00 AM
lophix's Avatar
hey matt, i know this might be a dumb q...but since we don't put water into the radiator, won't it be more of a "coolant" pump than a "water" pump?
Old Jan 12, 2004 | 10:14 AM
Matt93SE's Avatar
STFU n00b!
we DO put water in the radiator.. we also add antifreeze/coolant to it so the water freezes colder and boils hotter.
Mar 12, 2020 12:06 AM
scarletsosa
Aug 17, 2015 09:09 PM
CustomMax
Mar 4, 2001 10:02 PM
MSK
Nov 20, 2000 10:21 PM
