Gas Leak from Top Front of Engine
Old Jan 12, 2004 | 08:00 AM
Izzrock's Avatar
My 89 Max has developed a gas leak that appears to be comming from the top-right part of the engine toward the front of the car. It looks like its dripping from the fuel lines that feed the injectors (didn't remove air intake yet). Can the injectors be leaking fuel or does this normally happen to the lines and what is the best remedy for this type of problem? Any help appreciated!!!
Old Jan 12, 2004 | 08:53 AM
subs1000w's Avatar
yes you proboly need to replace all the rubber fuel lines
very common problem
Old Jan 12, 2004 | 09:00 AM
DaveinCT's Avatar
I just did it on my 91. You have to take off the upper and mid level intake to access the fuel rail. The rail then unbolts and you can remove the clamps and the old line. Measure the hose (injector grade hose must be used) and replace the hose. The big job is to remove all the vacuum lines and the intake. Make diagrams, take pictures and keep the bolts organized. A manual is a must for the sequence of intake bolt remove and install.
Dave
Old Jan 12, 2004 | 07:21 PM
rymo926's Avatar
try tightening the clamp with a long srewdriver.
Justinmc760
Aug 23, 2015 03:10 AM
scarletsosa
Aug 17, 2015 09:09 PM
Balkins
Aug 12, 2015 06:39 AM
