strange water flowing sound
Old Jan 12, 2004 | 03:01 PM
MikeThornton's Avatar
almost on a regular basis, shortly after i start my car, and i'm sitting there in park, i hear what sounds like water flowing under the hook, like the sound is comming from the engine compartment. when i rev the engine slightly it gets even lounder. after i've driven the car the sound stops. this is very odd to me, and i'm a little concerned, however the car runs great. anyone have any ideas on what the sound could be, or is it normal? by the way its a 92 SE. THANKS
Old Jan 12, 2004 | 03:22 PM
hotmax97's Avatar
same here any ideas?????????
Old Jan 12, 2004 | 04:14 PM
Paul89SE's Avatar
Look at recent posts. It's an air pocket in your heater core caused by recent cooling service (thermostat, water pump, flush and fill). You need to bleed the air bubbles out of the heater core because the heater core is the highest point in the cooling system.
Look at poor heater performance on this link it will help. http://maxima.theowensfamily.com/tsb...=1989&tsb=none
Old Jan 12, 2004 | 04:38 PM
drstillpatient's Avatar
hmmm...wierd...i thought this was only a problem for the 89-91 maximas? and they redid the heater design for his 92 max...
anyhow...yeah its an airlock.
Old Jan 12, 2004 | 05:01 PM
rcy's Avatar
rcy
Mine's a '92, and while I don't have the water flowing sound, I just installed a block heater and did a flush and fill, and I'll tell you, it's a major pain in the as5 trying to get all the air out of the system. I have no idea why they even have that bleed bolt, as it seems to do squat. I've owned several Honda's, a Grand Cherokee, and a Grand Caravan, none of which had a bleed bolt, and I don't recall having any trouble doing a flush and fill on them....
Old Jan 12, 2004 | 05:27 PM
yeah....i've never had airlock problems on any of my previous cars either...after doing the "home" version of the TSb method, my heating is much much better then what i started out with...but it only heats a little after the temp guage gets to the middle.
oh well...i'm moving to texas tomorrow...i wont need a lotta heat there hopefully!!
Old Jan 12, 2004 | 06:18 PM
broncoguy's Avatar
You'll need some....I moved here from Colorado (don't ask) and thought I wouldn't need it either. No below zero stuff, but it does get cold
Old Jan 13, 2004 | 08:30 PM
rcy's Avatar
rcy
No, but you'll find out if your A/C is up to the task...
Mahmuth
Aug 16, 2024 08:23 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
