ran with gtech over 300hp@8psi!
Old Jan 15, 2004 | 07:24 PM
4signs's Avatar
I just ran my car using my friends G-tech (We have a fellow 3rd gen on the board running 8psi /250hp wanted to run a test, those #s seemed kind of low) I set boost @8.5 psi (couldn’t get right on) plug the g-tech in jumped in and went out for a test drive. I headed to the highway, pulled over to the break down lane until I was clear of traffic. Set the G-tech @3200lbs and punched it. I had run 13.3 @109 and the g-tech displayed 314hp. Pulled over preparing to make another run and I noticed the engine was over heating, the gauge skyrocketed to H, I turned the heat on full blast, and wasn’t getting any heat! Open the hood and discovered coolant flowing out the water pump. Its –2deg outside, I have no heat but the car is overheating (go figure)
Moral of the story: a VE should put out more than 250hp @8psi and never test your car when its under 0 degs
Old Jan 15, 2004 | 07:34 PM
jim90gxe's Avatar
Do you have stock injectors?
Old Jan 15, 2004 | 07:50 PM
MrGone's Avatar
what!?!?!? always test the VE when it is below 0* outside... always! heheheheh
it was 18* out here the day I put my freshly ported intake manifold back on, first gear had absolutely no traction at all.... sadly it wasn't so much because of the porting
Old Jan 15, 2004 | 08:10 PM
AscendantMax's Avatar
man...that cold air can do cool that charged air going through your IC pretty good eh ? that could have been a factor for those numbers. i want a VE
Old Jan 15, 2004 | 08:16 PM
davebond007's Avatar
I'd just like to say that your car rocks man.
On my friends Gtech I ran a 15.3 @ 96 or so. W00t for me.
Old Jan 15, 2004 | 08:24 PM
Maroon'dMaxSE's Avatar
nice numbers man
Old Jan 15, 2004 | 09:08 PM
subs1000w's Avatar
although the HP from a GTECH isnt going to be quite as accurate im sure your easlily putting down within 25 hp of that especially since you ran a 13.3
just curouis but what is the reason that you cant make it to a dyno
and yes -2 degree + VE + 8psi = MADDDDDDDD HP
plus i bet your car wieghts more like 3300lbs with you in it especially with all that turbo crap because mine wieghs EXACTLY 3140lb and i wiegh 160lb so depending on your wieth and the extra pipeing and such your car could wiegh more like 3400lbs which is going to give you an even better HP reading on a gtech
none the less nice numbers because the gtech is very acurate in the 1/4 mile
Old Jan 15, 2004 | 09:26 PM
MrGone's Avatar
If you underrate the numbers on the gtech it makes the gtech give you underrated numbers which is good, makes the numbers more accurate.
Old Jan 15, 2004 | 09:35 PM
subs1000w's Avatar
true the other thing is
does the gtech estimate the numbers for Wheel HP or Flywheel HP
if FHP the numbers will be in the 275 WHP range but who knows the only real way is to step onto a dyno
Old Jan 15, 2004 | 09:39 PM
Matt93SE's Avatar
STFU n00b!
extreme cold + improper coolant mix = frozen radiator = exploding water pump.
doh!
Old Jan 15, 2004 | 09:45 PM
subs1000w's Avatar
whats the temp that will cause lets say 75% water and 25% antifreeze to freeze anyone know
MrGone's Avatar
pretty sure gtech goes for wheel because it is an accelerometer (spelling? lol). Plus it has no way to know the specific drivetrain losses.
Old Jan 15, 2004 | 09:58 PM
doh!
good thing houston is still in the mid 50s and 60s during the day
Old Jan 15, 2004 | 10:03 PM
Matt93SE's Avatar
STFU n00b!
that and my car is up on jackstands with the tranny in the garage
Old Jan 15, 2004 | 10:21 PM
MrGone's Avatar
sounds like I lost that bet. well atleast I dont get a swift kick in the nuts.
Old Jan 15, 2004 | 10:23 PM
dmontzsta's Avatar
Ford Only.
That is awesome. G-Tech can be VERY accurate if it is dialed in right. If you are laying down those numbers that is great! a 13.3 is great! I really hope you are laying them down, I would like to know more about your setup, the style piping it is. Can you PM me? I sent you an email about a week ago and never heard back, heh...I guess cause the email system is down
Old Jan 15, 2004 | 10:33 PM
MrGone's Avatar
Don- he had mandrels from JC Whitney. They cost him a bunch to ship because he was in Hawaii.
He had a chop saw on his driveway.
I can remember things
Old Jan 15, 2004 | 11:03 PM
Bryan H's Avatar
doh!
what captain obvious said
Old Jan 15, 2004 | 11:27 PM
lophix's Avatar
you'd have to know the freezing temp for antifreeze to figure that. Can't recall my chemistry too well, but you *might* be able to use vol. expansivity to calculate that using some other variables...i think...heck what do i know? i'm a cs major.
Old Jan 16, 2004 | 07:17 AM
Maxpwer's Avatar
No turbo, no care!
-84 Degrees Fahrenheit
Old Jan 16, 2004 | 07:19 AM
subs1000w's Avatar
are you serious or is that just a guess
Old Jan 16, 2004 | 07:40 AM
Maxpwer's Avatar
No turbo, no care!
Well, its a guess based on the purity of your system, but its accurate with in a few degrees.
Old Jan 16, 2004 | 08:10 AM
subs1000w's Avatar
so 4signs were you running 100% water
Old Jan 16, 2004 | 08:24 AM
DaBoxSE's Avatar
Good run bro. Whats the progress on the exhaust setup? Looks like yours and my car are having a tough time in this cold huh?
Old Jan 16, 2004 | 08:26 AM
Mizeree_X's Avatar
Getting back to his roots
You can approximate it with the freezing point depression equation: (change in freezing temp) = Kf*m2, where Kf is the cryoscopic constant (must look it up for antifreeze), and m2 is the molality of the solution (moles of antifree / kg of water). This equation is derived from the difference in solvent activities, which always befuddled me in thermo.
Old Jan 16, 2004 | 09:58 AM
Bryan H's Avatar
AAAaaAAaAAAaaaaaAAaaaHhhhhHHhhhh no more math please!!!!!!
Old Jan 16, 2004 | 11:21 AM
MaDMaX024's Avatar
4signs, when do i get to run you? it would be my pleasure to get smoked by a boosted VE
Old Jan 16, 2004 | 12:45 PM
D-sta's Avatar
I have my doubts about the the g-tech. I rather see what it can do on a dynapack it yields honest numbers compared to a dyno jet. But you are obviously running more than stock. Good job on the turbo kit
Old Jan 16, 2004 | 03:19 PM
2k3TitaniumSe's Avatar
What there is a turbo on a VE!
Old Jan 16, 2004 | 04:00 PM
MrGone's Avatar
Come here, You'll get smoked by a non boosted VE
more than one
Old Jan 16, 2004 | 04:29 PM
Maximan190's Avatar
3 white VEs post in a row
Old Jan 16, 2004 | 05:15 PM
MrGone's Avatar
I think its time for a white ve club
Old Jan 16, 2004 | 05:41 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i cant get over how nice your car looks !! what body kit is on there ??
Old Jan 16, 2004 | 08:31 PM
4signs's Avatar
I been really busy and dont have the time to really tune the car(bring it to the dyno) I still havent had the time to even finished the exhaust(I have 3inch down pipe heading out into the pass wheel well)
Old Jan 16, 2004 | 08:33 PM
4signs's Avatar
yes, until spring
Old Jan 16, 2004 | 08:34 PM
4signs's Avatar
just a modified stillen front lip to fit around the IC
Old Jan 16, 2004 | 08:44 PM
4signs's Avatar
no I replaced my water pump when I was in Hawaii, I only put 1 gal of anti-freeze,some water wetter and the rest water. I forgot to adj. for the change in climate when I moved over here It should of hit me when I heard the belts squeal
Old Jan 17, 2004 | 12:31 PM
pezking4's Avatar
white VE 5 speed club?
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
msellas
Sep 23, 2015 09:16 PM
junito1
Sep 23, 2015 12:14 PM
