Oh GNOES!!!
Old Jan 16, 2004 | 10:16 AM
Bill Brasky's Avatar
Seperated at Birth?
Oh GNOES!!!
Auto shop just called after doing my timing belt and water pump... they've found my rough idle/rich mixture problem (i thought it was the o2). 3 of my injectors are malfunctioning/leaking/not working so they need to be cleaned/rebuilt/replaced.
$50 bucks for the rebuild, $150 for the replacement.
It's nothing huge (the idle) but it's only going to get worse. Sadly, I don't think my dad wants it done... he says i drove it from Phoenix fine so whats the big deal... I told him a catalytic converter was a big deal (due to rich mixture) and gas milage was a big deal (when I first had it, it got 25-30 mpg, now i haven't seen it get better than 20).
Argh, and they have to take off the manifold too! that was my job!!!!
Old Jan 16, 2004 | 10:26 AM
internetautomar's Avatar
mod or sell?
so do the whole job yourself!
Old Jan 16, 2004 | 10:35 AM
Paul89SE's Avatar
If you do end up letting them do it ask them to save old parts. That way they change ALL 3 instead of just 1 or something along those lines.
Old Jan 16, 2004 | 10:37 AM
Jeff92se's Avatar
I'm needing a caw
Didn't you go to school for automotive repair?
Old Jan 16, 2004 | 10:53 AM
-shock211-'s Avatar
it'll get pricy if you have a shop do it. injectors aren't that hard to replace, plus the weather can't be too bad in WA so get outside and fix that max!
Old Jan 16, 2004 | 11:16 AM
KLoWnPR109's Avatar
So do you need a new cat too?
Old Jan 16, 2004 | 04:22 PM
MrGone's Avatar
Should have taken it to MrGone's shop.
I'm with Jeffy on that one, I dont understand it.
Old Jan 16, 2004 | 04:57 PM
davebond007's Avatar
Luftwaffles. When I drove your car it didn't seem like that was the case.
You know buying a VE is the only real way to fix it, right?
Old Jan 16, 2004 | 05:23 PM
MrGone's Avatar
maybe replace the O rings, but seriously, you will know if even one of your injectors is not working, and the way your car was running, they were all working. Leaking could be a possiability, I wasn't really paying any attention to it, but it sure didnt sound/run like one of the injectors was bad, let alone 3.
Old Jan 16, 2004 | 05:28 PM
Jeff92se's Avatar
I'm needing a caw
Check with ohm meter.
