does aftermarket y-pipe cause hissing at higher RPMs?
Old Jan 17, 2004 | 03:27 AM
drstillpatient's Avatar
I been hearing a low hissing sound at RPMs higher than 3k ever since i installed a cattman y-pipe (bought used). i was thinking it was a leak but someone told me some aftermarket y-pipes do that. is that true?
Old Jan 17, 2004 | 07:22 AM
Cliff Clavin's Avatar
Way out West
I have a cattman y and there are no "hissing" sounds or leaks. Did you put in new o-rings or use the old ones? How about the gasket to the cat?
Did you check the flex section out really well for problems? I would think that it would be louder than a hiss if it had some kind of leak. My original o-rings were pretty flat and worn out and they caused my stock y to leak and make all kinds of noise. I would have been fine by just replacing the gaskets, but I figured if I was going to take it off, I may as well get a better one.
I had my cattman on with the stock air box at first and it was very quiet, but still produced noticeable gains. Now, I have a PiggieRacing pop charger and that makes more noise than the y-pipe. I also have the stock cat and after cat still on.
Old Jan 17, 2004 | 09:51 AM
i got new o rings from nissan when i had that put in, as well as the gasket for the cat. the flex section had a thermal wrap on it since i got it so i couldnt completely check it out.
my guess is that the shop that put it on didnt use the new o-rings and just put the pipe on like that OR its the flex section? the thing is....now when i take it to a muffler shop..they see the thermal wrap and think its there to stop some leak an immediately blame the flex section.
Old Jan 20, 2004 | 06:34 PM
jkmay01's Avatar
Lil 8
sounds like the flex section, if u jack the car up and have some turn the car on and lightly rev the engine while u are underneadth. wear some thermal gloves and slightly move the flex section onthe pip and see if u hear the hiss more? since the y-pipe doesnt use hangers if u have used the new gaskets the only other place for the hiss u would think is in the flex section.
Old Jan 21, 2004 | 05:05 PM
StRacer718's Avatar
Pretty sure that the hissing sound your hearing is a exhaust leak. I haven't heard of y-pipes making that kind of sound.
Old Jan 21, 2004 | 06:47 PM
bonzelite's Avatar
wouldn't an exhaust leak make a puffing or pulsing sound and not a continous hiss? i have such a hiss, as you described. and i have a y-pipe. but i cannot claim a correlation. but you mentioned it.
Old Jan 21, 2004 | 08:38 PM
i got to hear the hissing sound thing from y-pipes at another forum. i was thinking the same thing...wouldnt a leak make a loud sound? like a usual leak in the exhaust does?
Old Jan 22, 2004 | 03:53 AM
Shift_my vq's Avatar
I had a wsp y pipe brand new on my 3rd gen and it hissed. I had wsp brand new on my 4th gen and it hissed. My best friend has a brand new budget and hisses. I barely hear or notice it though. It actualy helps me shift if I'm racing cause I just shift right after hissing dies down, and that's at 6k on my car wich is perfect cause there is not much up at 6500.
Old Jan 22, 2004 | 05:48 PM
so what do u think..why does it hiss?
Old Jan 22, 2004 | 08:12 PM
reygarcia's Avatar
Loved by MrGone longtime
I looked at my pipe before it was installed and the part where the flex pipe is the same on the inside. I think that is where your hissing is coming from.
pezking4's Avatar
Just intalled a y pipe on KINGMAX's 4th gen, and we noticed a hissing type sound at WOT. His is a Budget. I checked for leaks while the car was at idle. I assume some setups just make this type of sound.
Old Jan 25, 2004 | 01:02 PM
bonzelite's Avatar
i don't have any discernable leaks or losses in power. i think the hissing may be inherent in the way the exhaust gas flows through and over the surfaces on the inside of the pipe.
Old Jan 25, 2004 | 02:46 PM
yup...on mine..its the flex section leaking. just had it confirmed. now to find a flex section thats only 8 inches long. i got a qoute for $130 for changing the flex section...i think thats too much.
Old Jan 25, 2004 | 03:08 PM
jkmay01's Avatar
Lil 8
just get a new y-pipe from warpspeed talk to dallas it will almost be the same price, but with the madrel bent y-pipe u'll get more hp instead the OEM y-pipe!!!
Old Jan 25, 2004 | 06:15 PM
internetautomar's Avatar
mod or sell?
Can you weld?
$25 + ship for a new flex section.
Old Jan 26, 2004 | 02:29 AM
Can you weld?
JKmay...yeah it is a cattman pipe...i dont wanna spend anymore on my exhaust and get a whole new y-pipe...if i can find a used one in good shape i'll take that...but not a new one.
internetautomar...nope, no welding skills here ...let me get back to u about the flex section in a couple of days.
Apr 16, 2020 05:15 AM
Quickywd01
Sep 21, 2016 09:36 PM
Need help
23
Oct 2, 2015 08:56 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
