misfire in a vg
Old Jan 21, 2004 | 07:34 PM
Laly's Avatar
misfire in a vg
my max is misfiring. i starting pulling the wires from the distributor so that i can find out what cylinder its coming from. it is #5. i am thinking it could be the fuel injector. i have new wires and new plugs. i think im going to change the rotor too before i assume its the injector. how hard is it to change an injector on the vg. ive changed one on my old ve and it didnt seem to hard. but it looks like you have to take off the top cover on the engine to change on the vg. anyone have any tips or suggestions. thanks
joshua
Old Jan 21, 2004 | 09:51 PM
mtcookson's Avatar
all you have to do is take off the upper manifold and then the spacer piece that is in between the upper manifold and lower manifold. once you do that you have access to your injectors. pretty straight forward.
Old Jan 22, 2004 | 06:41 AM
broncoguy's Avatar
Not hard, couple hours work. My suggestion is that while you are in there you also ohm-out your other injectors and check/replace the fuel lines on the rail. Those are both things that require removal of the intake, so might as well do it once. Might want to have a set of gaskets handy too, depending on how old the current ones are.
Old Jan 22, 2004 | 07:42 AM
-shock211-'s Avatar
to mtcookson & broncoguy suggestions
*test the injectors
*replace the fuel hoses
i can't quite remember, but
injectors should read 13ohm resistance if they're working properly right?
anything lower or higher means your injectors are going bad or they are fubar'd
Old Jan 22, 2004 | 07:48 AM
broncoguy's Avatar
Yeah, I think it's a range of 10-14 ohms...
internetautomar's Avatar
mod or sell?
[QUOTE=-shock211*test the injectors
anything lower or higher means your injectors are going bad or they are fubar'd[/QUOTE]
10-14 ohms IIRC
Old Jan 23, 2004 | 09:30 AM
Laly's Avatar
thanks guys, im going to order the parts today. try and do the work tomorrow. ill let you know how things go.
Old Jan 23, 2004 | 09:48 AM
DopeAZmaxima's Avatar
I just replaced my #5 in my VG its not hard just time consuming Good luck you shouldnt have to much trouble
Old Jan 23, 2004 | 01:58 PM
doomtoo's Avatar
Or you can pay a mechanic $500 to do one, or $1100 for all 6... I shoulda learned about cars earlier.. :L
Old Jan 23, 2004 | 03:26 PM
-shock211-'s Avatar
i learned the hard way too...
but now i know how to do it and i saved myself a tonne of money this past year replacing 3 injectors myself.
Old Jan 24, 2004 | 09:09 PM
Laly's Avatar
well did it today. man was the pain in the a$$. but i still get a misfire. i think i screwed up though. when i put the new injector in the fuel rail, i noticed that it wouldnt go in all the way. i figured when i put hte cover back on(the piece with the two phillips screws) that it would snap into place. i did not put anything to lube the o-rings as i placed the injector back into the fuel rail. im guessing that i am leaking fuel because i am still getting i misfire. the car is running a little smoother but the misfire is there nonetheless. the car also smells of fuel.
the game plan: do everything all over again. should go quicker because i know what im doing. check the o-rings on injector for damage. replace if need be. make sure i use vaseline this time. i also want to clean the other injectors. what is the proper way to clean the other injectors? thanks guys for the help.
jmlee44
Oct 2, 2022 02:13 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
ballerchris510
Sep 11, 2015 05:29 PM
