need help: oil pan removal?
Old Jan 22, 2004 | 11:32 AM
dmitriy's Avatar
Has anyone removed/replaced oil pan in VE? Any tips you can give me? Search is down right now, but I think I've seen some sort of guides about it in the past.
Thanks,
Dmitriy
Old Jan 22, 2004 | 12:10 PM
KLoWnPR109's Avatar
Drain oil. There are a bunch of 10 mm bolts along the underside of the pan where it'll attach to the block. Take those out and then I had to get a flathead to wedge in there because of the sealant or whatever that was used.
Old Jan 22, 2004 | 12:13 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I wouldn't use a flathead to pry it off...knock it with a rubber mallet rather. wouldn't the flathead bend and damage the seal between the block and pan?
Old Jan 22, 2004 | 12:20 PM
KLoWnPR109's Avatar
The majority of the seal actually come off with the pan. I just put the flathead in on the corners and then it came off pretty easily.
Old Jan 22, 2004 | 12:30 PM
subs1000w's Avatar
i just read the FSM pages EM54 and EM55 they say support the engine buy placing a jack under the crank pulley, remove ypipe, remove crossmember, remove the 18 oil pan bolts, in bold it says dont use a screw driver you could damange the mating sufaces. it says use sutable tool and remove pan. im sure you could use a small screw driver but just be carfull and dont pry on it hit it with a hammer to the left or right to break the seal. the tool they show is what looks to be a wide blade of some sort
Old Jan 22, 2004 | 02:00 PM
KLoWnPR109's Avatar
Yeah, thats what I did. Guess I should have just explained myself besides using the word pry.
Old Jan 22, 2004 | 02:19 PM
dmitriy's Avatar
Wow, thanks guys. It's an interesting idea to support the engine by crankshaft pulley... wouldn't the weight of the engine damage the pulley (bearings)?
How difficult is it to remove the Y-pipe?
Old Jan 22, 2004 | 02:23 PM
KLoWnPR109's Avatar
Its easy. Just make to sure and soak the bolts with some PB or WD40 beforehand. They might be rusted or stuck on there good.
3 14 mm on the front manifold and 3 more on the rear. The 2 that connect to the cat are either 15 or 17, the size evades me as this point in time.
Old Jan 22, 2004 | 02:24 PM
dmitriy's Avatar
Also, would blue RTV silicone be good enough for the gasket? Or should I use hi-temp stuff?
Old Jan 22, 2004 | 02:25 PM
dmitriy's Avatar
What about center crossmember... I assume it's just a few bolts in the front and then engine mounts that are on it, right?
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
