Fuse Help!
Hi, Im having a problem finding a fuse in my 91 GXE. A couple of nights ago my dash lights, corner lights, and tail lights all went out. I can't find one blown fuse in the whole car!! I looked in all 3 fuse box's that i know of. What caused this problem and how can i fix it? Thanks alot for your help!
Okay, the fuses you need to replace are in teh knee panel under the steering wheel. Sometimes the fuses are burnt even when they appear to be okay. Replace the appropriate fuses according to the list on the back of the cover with higher amperage fuses (such as 15 or 20 Amps). You will probably have to replace about 4-5 fuses. The reason why they blew is that your rewiring the corners overloaded the circuit. Happened to me too. Good luck.
Peter
Peter
