Having problem with parking/dash lights switch
Old Jan 28, 2004 | 07:42 PM
Maxdude's Avatar
When I turn the switch to turn on my parking lights/cluster and dash light, sometime it works and sometimes it doesn't. Eventhough the switch is turned on both parking lights and all interior lights turn off. Then when I give it a few hits and punches to the light switch handle it comes back on but still turns off. Sometimes soon sometimes after a few minutes.
What should I check first?? Short somewhere?? Fuse???
HELP!!!!!!!!!!!!!!!!!
Old Jan 28, 2004 | 08:42 PM
harrymay's Avatar
check tailight fuse, check the switch and clean it, also check for a short in the tailight assembly
i had a similar problem where my dash lights wouldnt work, it turned out i had a bad fuse and a short in my tailights
Old Jan 28, 2004 | 10:34 PM
maxmvp's Avatar
I am having a similar problem, but my keeps blowing the fuse. I have ordered a new swith from nissan. It only cost me $63. The junk yards wanted $50. If it gets worse, I would try changing the switch.
Old Jan 29, 2004 | 06:28 AM
harrymay's Avatar
it might be a short in yalls tailights, take a multimeter and test around, also this is a no brainer, but make sure its the right amp fuse
Old Jan 29, 2004 | 06:54 AM
subs1000w's Avatar
check for shorts first
if no shorts are found replace the switch its ussually the problem ive had 2 go bad on me
Old Jan 29, 2004 | 07:36 AM
Maxdude's Avatar
Thank you all. I'll add it to my list of weekend projects.
Old Jan 29, 2004 | 11:17 AM
GilroyWasHere's Avatar
This happened to me a while ago. Did you install an aftermarket Stereo Head Unit? That might be the problem. I had the wires crossed.
vingodine
45
May 21, 2016 12:46 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Samedi
Aug 13, 2015 04:05 PM
kjm900r
Aug 5, 2015 07:14 AM
yat70458
Aug 3, 2015 01:16 PM
